no reverse, gsr swapped ek.
I was on a spirited drive the other night and ground 5th gear pretty bad. Yes, i was going way to fast, about 115 to be exact. as soon as i heard the grind i slowed down and then shifted into 5th, at about 90 mph. went into gear fine. got to my destination and parked the car fine, thinking that i had just been an idiot and tomorrow nothing bad would happen. Well, it did. woke up in the morning to no reverse. I have had minor issues in the past where it took me a few tries to get it into reverse, but it always went. well now it simply wont. I have tried putting it in while moving backward, revving and putting it in, going quickly from 4th to reverse(not while going forward), but to no avail. it is really shitty as i was just about to tear apart my motor for a turbo build. My question is do you think that it is a specific tranny problem that can be fixed, or would i be better off replacing the whole trannny( i have a gsr swapped ek with gsr tranny) with a LSD? budget really isn't a concern as this car is my passion, but it would really suck to buy a whole new tranny if mine was a simple fix. I know this was alot to read, but i wanted to get as much info out there as possible. if you have any experience or input i would forever be in you debt. worst part about it is that i haven't driven my baby in a week. SOOOOOO SHITTY.
I think i remember someone telling me 5th and Reverse are on the same synchro. Search and see if you can double check. Doesnt sound like good news. You can try synchro mesh but i think it needs a rebuild. I had a GSR trans that fifth started grinding on and reverse eventually went. I just replaced it with a b16 trans off the classifieds after getting crazy quotes from transmission places. Takes a day w/ the right tools.
