pressure regulator or pump
Old Jul 18, 2002 | 08:17 PM
Griffins_Importuning's Avatar
Default pressure regulator or pump
i was just curious if my stock hf fuel pump meets the needs of the b16. should i upgrade to a larger pump or am i good with the fuel pump that is in it now.the engine seems to run fine except at low idel when i dont give it much gas. and then it opens up and runs fine.
Old Jul 21, 2002 | 06:28 AM
Default Re: pressure regulator or pump (Griffins_Importuning)
anyone?
Old Jul 21, 2002 | 07:15 AM
wronghand's Avatar
I would think that you would be fine. The HF and Si use the same fuel pump. If you are real worried pick up a fuel pressure gauge.
trustdestruction
Jun 28, 2010 10:45 AM
trustdestruction
Lsos
Jan 16, 2003 11:56 AM
Andrew 825SM
Nov 17, 2002 01:42 AM
stupidfast
Sep 19, 2002 10:42 AM
