removing the door chime?
Old Jul 18, 2002 | 08:12 PM
crujones's Avatar
Default removing the door chime?
can this be done? my girl hates that thing with a passion. thanks.
Old Jul 18, 2002 | 08:35 PM
dexter00's Avatar
Default Re: removing the door chime? (crujones)
I would like to know too, if anyone knows?
BW's Avatar
BW
http://civic.vtec.net/modific/94ex.htm#Override
hope thats helps
Old Apr 8, 2006 | 02:32 PM
kodou's Avatar
Default Re: removing the door chime? (BW)
crap. the link is dead. i wanna disable that door chime as well. it annoys me to no end.
Old Apr 8, 2006 | 04:06 PM
old man neri's Avatar
Default Re: removing the door chime? (kodou)
You could try just jumping/disabling the switch in the door jam. Down side is it disables the dome light door setting.
Old Apr 8, 2006 | 04:09 PM
Syndacate's Avatar
from what I hear you can unscrew the switch simply with a philips screw driver, only problem is if you have an alarm system it won't arm when you shut the door
Old Apr 8, 2006 | 04:37 PM
tallyturbo's Avatar
Default Re: (Syndacate)
there was this same thread 30 min ago. here is what to do. take the plastic peaces off on you ignition colum. then look unted the ignition and you will see a small philips head screw. there should be a small black box there. unscrew the screw and let the thing dangle. and voila no more chime.
Old Apr 8, 2006 | 07:08 PM
Markb16a's Avatar
yea i did that with my crx unscrew the ignition thing and its in there and lil square black box thats the door chime just disable that and your straight.
Old Apr 8, 2006 | 08:32 PM
92hatchling's Avatar
Default Re: (Markb16a)
just find the chime and un hook it its some where under the dash
pwyley
Acura TSX
Apr 2, 2018 02:32 PM
dlew48
Feb 28, 2012 08:28 AM
William1991b
Jun 26, 2011 04:00 PM
pr0j3xt01v1c
Honda Civic (2001 - 2005)
Aug 1, 2008 02:59 PM
