93 hatch SI. changed rear calipers now brakes on don't stop. HELP!
Old Jul 1, 2008 | 03:27 PM
DeadBunny's Avatar
Default 93 hatch SI. changed rear calipers now brakes on don't stop. HELP!
As the title says. I changed my rear calipers and now my brakes are stopping mostly on the passenger rear. The proportioning of the brakes were fine before I changed the rear calipers. Iv bleed the hell out of the system. Iv use multiple bleed order such as Right rear, Left front, Left rear, Right front and bleeding from furthest to closest to the master cylinder.
The only inconsistency I see is that when I bleed the rear right, more fluid comes out than the rear left.
Old Jul 1, 2008 | 04:55 PM
DeadBunny's Avatar
Default Re: 93 hatch SI. changed rear calipers now brakes on don't stop. HELP! (DeadBunny)
UPDATE!!
just took off the rear drivers side caliper to fiddle around with it. screwed the plunger in and out and now the pedal doesn't go all the way to the floor. still stopping mainly on the rears. Anyone ever heard of having to proportion the rear calipers at calipers them selves?
Old Jul 1, 2008 | 05:30 PM
gizzerhatch's Avatar
on your civic you have to bleed the brakes right rear, right front, left rear, and then left front.
rajan
Nov 2, 2016 06:01 AM
TheGreatBamDeanO
10
May 14, 2009 04:52 AM
DeadBunny
May 24, 2008 06:31 PM
