Post up your Hood Spacers!!!!
Old Jul 1, 2008 | 03:03 PM
importuner_sc's Avatar
Default Post up your Hood Spacers!!!!
I've seen it before in a few mags, and I wanted to see if anyone on H-T is doing it.
I don't know if there is another term for it or not but you put the spacers on the hinge on your hood and lift up the back ....ahh screw it just post em!!!
Old Jul 1, 2008 | 03:13 PM
HondamanXxX's Avatar
GO GIANTS!
Default Re: Post up your Hood Spacers!!!! (importuner_sc)
Seen one, seen them all.
Old Jul 1, 2008 | 03:15 PM
RICKYritethere's Avatar
"jdm hoodprop"
Old Jul 1, 2008 | 03:18 PM
N1 Andy's Avatar
R.I.P. Andy
Default Re: Post up your Hood Spacers!!!! (HondamanXxX)
i do home theater installations and when we hang plasmas there are shims in the hardware for the wall mount that work perfect! thats what I used. Im about to market them and charge ridiculous prices for them lol
Old Jul 1, 2008 | 03:39 PM
ek9=]'s Avatar
Default Re: Post up your Hood Spacers!!!! (N1 Andy)
Umm thats not even popped???
Old Jul 1, 2008 | 03:46 PM
The Collin's Avatar
It's not? What do you call that gap? Not my cup of tea, but that's definitely popped. Maybe not as much as some, but it is indeed mad tyt3 popped y0.
Old Jul 1, 2008 | 03:49 PM
ek9=]'s Avatar
Default Re: (99_hb_on_air)
I can barely see it...
Old Jul 1, 2008 | 04:34 PM
WeeMan's Avatar
From: Put it in..Take it out... Put it in..Take it out, United States
Default Re: (-Gambit-)
Pointless
Old Jul 1, 2008 | 04:48 PM
thatkid's Avatar
This is know to crack windshields.
Old Jul 1, 2008 | 04:58 PM
what gsr's Avatar
Default Re: (thatkid)
super wack
Old Jul 1, 2008 | 05:04 PM
SuckMyDOHC's Avatar
fugly
Old Jul 1, 2008 | 05:06 PM
nightrider's Avatar
Default Re: (WeeMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WeeMan &raquo;</TD></TR><TR><TD CLASS="quote">Pointless
pretty much unless there is a H2B.
Old Jul 1, 2008 | 05:13 PM
toyomatt84's Avatar
Sanji
Default Re: (nightrider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightrider &raquo;</TD></TR><TR><TD CLASS="quote">
pretty much unless there is a H2B. </TD></TR></TABLE>
With my K24, I ran small props to clear the PS belt better.
Old Jul 3, 2008 | 07:21 AM
Default Re: (toyomatt84)
not mine
Old Jul 3, 2008 | 07:42 AM
retroFIT's Avatar
Default Re: (importuner_sc)
This is just like the popped collar fad...
Old Jul 3, 2008 | 09:01 AM
BlackoutVTi's Avatar
Default Re: (retroFIT)
Its only use is to clear engine swaps that don't quite fit all the way in the bays of certain cars. Don't let people tell you this is for aerodynamics, don't let them tell you it's for evacuating heat from under the hood...it does nothing but put the hood up about an inch or so, and make you look like you've got frame damage.
Anywho, for the sake of diplomacy, I must interject that my statements about the looks of the jDmH0OdPr0p are in my opinion, and you should do whatever you like.
Old Jul 3, 2008 | 10:44 AM
EpicKills's Avatar
Banned
Default Re: (BlackoutVTi)
Ditto ^
To me it just looks like frame damage.
Old Jul 3, 2008 | 12:55 PM
PI$TOL's Avatar
* B A N N E D *
Default Re: (EpicKills)
Old Jul 3, 2008 | 01:02 PM
Loco-B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">With my K24, I ran small props to clear the PS belt better.</TD></TR></TABLE>
^^^the only reason why i would run a hood prop..........to clear a swap.
Old Jul 3, 2008 | 01:04 PM
AMLS4dr200whp's Avatar
Default Re: (Kurumi)
is there a write up on how to do the hood spacer?
Old Jul 3, 2008 | 01:06 PM
-Gambit-'s Avatar
Default Re: (AMLS4dr200whp)
go to home depot, get some longer screws, some spacers and place spacer in between the hood and hinge. then screw it all together. Then your done and have a hood that doesnt fit.
Old Jul 3, 2008 | 02:53 PM
YOUalreadyKNOW's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMLS4dr200whp &raquo;</TD></TR><TR><TD CLASS="quote">is there a write up on how to do the hood spacer? </TD></TR></TABLE>longer bolt + skateboard bearing = spaced hood lol
here's my old sol. RIP
Old Jul 3, 2008 | 03:09 PM
cubanSiR's Avatar
* B A N N E D *
admin....close this thread!!! pointless!
Old Jul 3, 2008 | 03:16 PM
Default Re: (YOUalreadyKNOW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YOUalreadyKNOW &raquo;</TD></TR><TR><TD CLASS="quote">longer bolt + skateboard bearing + large engine = useful spaced hood</TD></TR></TABLE>
Fixed.
PS- what are you doing here, I thought you were banned.
Old Aug 22, 2009 | 08:00 PM
psychotech's Avatar
Import Tuner proved that hood spacers help the cooling ability of the car. I don't have the issue on hand right now but that issue is the reason I want to put them on my car.
