Kic's Wheel spacer question
If I run 10mm Kics Wheel Spacer in the front, will it fit? I heard something about the hub bore is too small.
Can someone clarify for me please? Thanks!
Munkyw3rkz.webs.com
as long as they have a hub centric spacer for the S2K your A-OKAY.....
if not and the spacer hub is too small get it bored out.....
I run 15mm spacers in the front to clear my brakes and the fitment is very flush. This is going to depend on the wheel size and offset though... What size are your wheels?
I didn't think they made a 10mm spacer with studs pressed in. If there are no studs pressed in, and there just regular spacers then you will HAVE to install extended studs in the front.
The standard spacers kicks makes will not fit w/o the center being bored out a bit. They do however make spacers that will fit the front of the S2000 specifically.
