oil guage
Old Jul 1, 2008 | 02:42 PM
b18 hatch mike's Avatar
Default oil guage
i need to get a electronic oil pressure gauge if i get one right
Old Jul 1, 2008 | 03:03 PM
hotrod99's Avatar
Default Re: oil guage (b18 hatch mike)
both will work,the mech. takes alittle bit longer to install though and you need to run a isolator so you dont have hot oil coming into the cabin
Old Jul 1, 2008 | 03:04 PM
Default Re: oil guage (hotrod99)
well thats the one i got is thier any kinda write up on the install
Old Jul 1, 2008 | 03:06 PM
hotrod99's Avatar
https://honda-tech.com/zerothread?id=2019829
Old Jul 1, 2008 | 06:13 PM
thanks man gauge is all hooked up now i just have to put the head on and hope it dont leak
Old Jul 1, 2008 | 06:21 PM
do you think i could get away with not using a ISOLATOR
Old Jul 2, 2008 | 03:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18 hatch mike &raquo;</TD></TR><TR><TD CLASS="quote">do you think i could get away with not using a ISOLATOR </TD></TR></TABLE>
Old Jul 2, 2008 | 03:50 PM
hotrod99's Avatar
you can chance it if you want but it would suck to have hot oil spray in your face...its expensive but worth it in my opinion
Old Jul 2, 2008 | 04:27 PM
Ketone's Avatar
I never had a problem with leaking with my mechanical oil pressure gauge. Just be sure to buy the proper fittings and braided line. DO NOT use the fittings and line supplied with the kit, that will cause your gauge to leak.
Old Jul 2, 2008 | 08:39 PM
soontobeboost's Avatar
i didnt have one on my car and its been fine for like 2 + years now. just use a steel braided oil line
Old Jul 3, 2008 | 10:34 AM
Default Re: oil guage (soontobeboost)
well what size line should i run and where should i buy the fittings
TylerC161
May 29, 2007 12:00 PM
racingant
16
Jan 23, 2005 10:16 PM
1.8T_EG
Apr 18, 2003 08:00 AM
SPOON_BeIgHtEeNsEe
Mar 4, 2002 05:24 PM
speedymon
Dec 22, 2001 11:34 AM
