Innovative Cable to Hydro Swap
Old Jul 1, 2008 | 02:40 PM
jdmhondamotive's Avatar
Default Innovative Cable to Hydro Swap
i just got this in the mail.
has anyone used this set up?
im having a hard time figuring out where to mount it up.
...in other words im lost, pics would help
Modified by jdmhondamotive at 6:37 PM 7/1/2008
Old Jul 10, 2008 | 08:30 AM
thapimpfromchi's Avatar
Default Re: Innovative Cable to Hydro Swap (jdmhondamotive)
How much was that?
Old Jul 10, 2008 | 08:40 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
The most common place i've seen it mounted is by the rad.... run the cable along the drivers side of the motor and put it with the cmc facing out towards the passenger side fender... that way your cable isn't bound up and you can run a relatively short s/s line to your CSC.
Old Jul 10, 2008 | 08:52 AM
CRX_RR's Avatar
Default Re: (ComeOnKip)
heres where your suppose to mount it i guess.
Old Jul 10, 2008 | 08:53 AM
Default Re: (CRX_RR)
lol. i thought you were being a smart *** for a sec, until i looked deep into that bumper.
Old Jul 10, 2008 | 08:56 AM
CRX_RR's Avatar
Default Re: (thapimpfromchi)
hehe works great
Old Jul 10, 2008 | 09:53 AM
iluvmyef9's Avatar
this is where i mounted mine but i think that i looks way better then by the radiator it a lil fab work but it not that hard
their is two foutteen millimeter bolt hole in the bottom i took a 1/4in piece of flat mild steel and drilled the holes out on the bottom of the hyrdro coversion and then the two twleve millimeter holes on the tranny drilled the holes out and mounted it does not move around its solid and in place no play at all
here is another view
and the whole bay
Old Jul 10, 2008 | 10:03 AM
CRX_RR's Avatar
Default Re: Innovative Cable to Hydro Swap (iluvmyef9)
how long you had that in? how many miles till you have to refill again?
Old Jul 10, 2008 | 10:54 AM
iluvmyef9's Avatar
Default Re: Innovative Cable to Hydro Swap (CRX_RR)
i have had it for over 3000 miles and i have never had to fill it up or op it off exceot for when i filled it up and i have a stage 3 6 puck non sprung act clutch and pressure plate with a fidanza fly wheel grabs nasty as hell
Old Jul 10, 2008 | 02:53 PM
gearhead16's Avatar
I put mine in the bumper aswell
Modified by gearhead16 at 5:57 PM 7/11/2008
Old Jul 16, 2008 | 09:10 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: Innovative Cable to Hydro Swap (gearhead16)
are you still running a front trans mount?.. which version of the kid did u get?.. street or race?
Old Jul 16, 2008 | 09:13 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvmyef9 &raquo;</TD></TR><TR><TD CLASS="quote">this is where i mounted mine but i think that i looks way better then by the radiator it a lil fab work but it not that hard
and the whole bay</TD></TR></TABLE>
happen to have anymore detailed pics? where you mounted your kit how does it push on the slave cylinder?.. there's a hose from the kit to the slave cylinder right?..
Einhander276
16
Feb 9, 2011 02:03 PM
Maleek
Jan 3, 2010 03:44 AM
Rease3
14
Jun 5, 2009 03:29 AM
biassj
Mar 6, 2004 05:22 AM
Jared
Nov 1, 2003 09:59 PM
