Need help removing front strut fork...
Old Jul 1, 2008 | 02:10 PM
g2tegsown's Avatar
Default Need help removing front strut fork...
Alright so I got the car jacked up, tire off, I got the Pinch Bolt out, I got
the damper fork bolt out, and now I am realizing that the fork is TIGHTLY
fasten to the bad strut and it needs to be removed to take out the strut.
Any tips or tools that will help out here?
The method I was trying was using a screw driver to pry it apart, it started
to work for a second... but then it just stopped opening it enough to bring
the rest off... well without spending 4 hours trying...
I figured I would see if anyone had a "oh you just do it like this..." and you’re like "ohhhhhhhh yeah... wish I knew that 4 hours ago."
Thanks
Old Jul 1, 2008 | 02:28 PM
4crx4me's Avatar
Default Re: Need help removing front strut fork... (g2tegsown)
Did you loosen the two 10mm mounting nuts on the shock tower inside the engine bay? And don't forget the brake line/hose bracket.
Old Jul 1, 2008 | 02:56 PM
black0hatch's Avatar
Default Re: Need help removing front strut fork... (4crx4me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me &raquo;</TD></TR><TR><TD CLASS="quote">Did you loosen the two 10mm mounting nuts on the shock tower inside the engine bay? And don't forget the brake line/hose bracket.</TD></TR></TABLE>
there 14mm.
what i would do is take a flat head screw driver and hammer it into the gap get it stuck in there then try hammering it off from the top. leave the 2 14mm top ones for last.
Old Jul 1, 2008 | 03:28 PM
4crx4me's Avatar
Default Re: Need help removing front strut fork... (black0hatch)
You're right. I was thinking about the brake line clamp bracket bolts, my bad.
Old Jul 1, 2008 | 08:41 PM
g2tegsown's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black0hatch &raquo;</TD></TR><TR><TD CLASS="quote">
what i would do is take a flat head screw driver and hammer it into the gap get it stuck in there then try hammering it off from the top.</TD></TR></TABLE>
That sounds like it might work out The only problem is how tight it is in the wheel well
Old Jul 1, 2008 | 08:47 PM
greddy2die's Avatar
The brake lines don't matter they are attached to the strut. Try to spray wd40 where the strut and fork meet it might be rusted on ? slap each side of the fork lightly with a rubber mallet see if it breaks loose. Mine came off rather easy it wiggled off.
PS you only have to worry about taking out the 2 bolts that hold the fork to the LCA and the strut/fork bolt.
Old Jul 2, 2008 | 12:33 AM
24TEN's Avatar
PHANTOM MENACE
Here's what you do. Leave the two 14mm holding the top of the assembly to the body. Leave the bolt that goes through the LCA and bottom of the fork. Only remove the small pinch bolt. Spray your WD40, pry the fork open, etc. The trick is to use the weight of the brakes to pull down on the fork to seperate it from the bottom of the strut. You can hit downward on the LCA also with a mallet if you feel the need to, but it should be MUCH MUCH easier to use the LCA/Brake/Hub assembly as leverage on the fork to separate it from the strut.
Old Jul 2, 2008 | 05:58 AM
Jonathan_ED3's Avatar
WD40 is marginal at best.
Load that bad boy up with some PB Blaster!!!! Let it soak for a few min and give it some taps with a hammer. Then separate it!
rollinhonda3
Sep 11, 2010 11:36 AM
JDM_EK_wanabe
14
Feb 18, 2007 11:03 AM
huge230
Aug 24, 2005 07:13 AM
FunkDaddyFresh
Mar 23, 2004 06:32 PM
Kasper.
17
Jun 29, 2002 10:04 AM
