mini me with p28 ecu run fine?
Old Jul 1, 2008 | 01:30 PM
immajackuup's Avatar
Default mini me with p28 ecu run fine?
I owned a 2000 civic coupe dx,about to do a y7/y8 mini me.
wanted to know well the car run fine if i use a virgin manual p28 ecu?
As of why i want to use the p28 ecu because there is no need for knock sensor and fuel pressure tank sensor as the p2p obd2b ecu be looking for.
plus those sensor are pricey.
yes, i am getting the jumper harness to convert obd2b to obd1.
Old Jul 1, 2008 | 01:45 PM
Syndacate's Avatar
Default Re: mini me with p28 ecu run fine? (immajackuup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by immajackuup &raquo;</TD></TR><TR><TD CLASS="quote">I owned a 2000 civic coupe dx,about to do a y7/y8 mini me.
yes, i am getting the jumper harness to convert obd2b to obd1.</TD></TR></TABLE>
Yeah, a P28 would be your best bet as far as not modifying things goes, though the tables won't be an exact lineup, they'll be pretty damn close.
I would go with a P2P though - the Y8 doesn't have a knock sensor, I don't believe (I could be wrong), and I don't know anythin gabout a fuel tank pressure sensor - all you need to do is run the wires for the secondary O2 sensor, I believe.
team 15
Jan 11, 2007 05:59 AM
dkrex001
Oct 1, 2006 10:34 PM
importboi22
Nov 18, 2004 07:53 AM
SETI20
Aug 17, 2004 11:57 AM
thehondaguru
Nov 26, 2003 06:55 AM
