Part number, Please and thank you! (Searched)
If you would be so kind. I need a part number for the part highlighted in red.
(image borrowed as a reference)
I need two of these, one for each location specified below.
Thanks!
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrod99 »</TD></TR><TR><TD CLASS="quote">thats weird...i looked threw delray acura website and they had the picture but did not list part #'s for those peices that you need.</TD></TR></TABLE>
That is weird. Thanks for trying.
if you are trying to purchase just the single cam cap then good luck. they are machined/cast as part of the cylinder head. honda will not sell you one separately. you need to try and find a used one and hope it lines up correctly and not cause your camshaft to seize up.
good luck
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">if you are trying to purchase just the single cam cap then good luck. they are machined/cast as part of the cylinder head. honda will not sell you one separately. you need to try and find a used one and hope it lines up correctly and not cause your camshaft to seize up.
good luck</TD></TR></TABLE>
ouch *note to self never loose those*
Exactly, and since he lost one on each cam side he would have to get both sides line honed if he did find some other caps, and that alone would cost a couple hundred bucks.
Dang, I'm looking for the other cam cap, the one the dizzy bolts up to. It's almost impossible to find, since the dealership never offered it for sale.
Actually I did not lose them. When I took off my valve cover I noticed the valve cover studs were stripped in those two locations. That's why I want to replace those pieces.
If you just stripped the studs then replace the studs. Number 18 below
http://www.hondapartsunlimited...dIrno=
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nataku »</TD></TR><TR><TD CLASS="quote">Actually I did not lose them. When I took off my valve cover I noticed the valve cover studs were stripped in those two locations. That's why I want to replace those pieces.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nataku »</TD></TR><TR><TD CLASS="quote">Yeah unfortunately it's not the studs that stripped out.
Thanks anyway!</TD></TR></TABLE>
WTF? Make up your mind.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg »</TD></TR><TR><TD CLASS="quote">WTF? Make up your mind.</TD></TR></TABLE>
Sorry that's my mistake. It's the part the stud screws into that is striped out. I'll going to try an experiment today to see if I can salvage this.
integlspwr2k
12
Jan 27, 2006 02:44 PM
