List of d-series engines and their specifications
Old Jun 30, 2008 | 08:35 PM
austinkli's Avatar
Default List of d-series engines and their specifications
due to the fact that I was earlier having a debate about d-series engines with someone on here, and the subject has come up lately, and also due to the fact that I have so far done 1000 posts and contributed nothing but terror to H-T I figured this might help some people. Also majority of people with a 92-00 civic have or had stock d-series motors so here goes.
I would like to state before i do this that I can not be 100% accurate on every single thing I post, so if you know of something i left out, or something I did wrong, let me know so I can change it.
The d-series engine
The d-series engine is an inline 4 cylinder engine commonly used in hondas. Most commonly the civic, CRX, and first generation integras. Its displacement ranges between 1.2 and 1.7 liters depeding upon the specific model. While the most common d-series motor is a SOHC, this engine DOES come in both SOHC and DOHC. Some SOHC models come with vtec, but none of the DOHC models do.
D series vs B series
The d-series engine was first introduced in 1984 and continued production until the 8th gen civic. The d-series is a readily available and fairly cheap engine that is easy to mod. While this engine is not quite as durable as the b-series and may not provide as much power, it is still very durable.
Common way to get more power from a d series
There are two common ways to bring more power from a d series engine. Mini me and Forced Induction.
Originally Posted by wikipedia
One of the most popular and effective methods of achieving greater power from a D-series motor is replacing the cylinder head with one from a more powerful D-series motor. This is usually done between D16A6 and D16Z6 or D16Y7 and D16Y8 engines, however, can be performed in other combinations as well; such as a D16Z6 head on a D16Y7 or D15B2/B7 block. The Z6 and Y8 heads are VTEC (Variable Valve Timing and Lift Electronic Control) equipped, and increase horsepower significantly over stock levels. This operation is known as a "Mini Me" or partial swap. Mini Me's are popular because they offer a substantial performance upgrade by adding VTEC to the motor at a relatively low cost. Simply adding a VTEC head to a non-VTEC block will not increase horsepower alone. This is because the VTEC circuit must be activated and accompanied by a new 'high cam' fuel map from the car's ECU.
To list all the d-series engines I could find with specs: (some of these I could not find specs on, please let me know if you have answers)
1.2 Liter
D12A - I have no specs on this, will update soon
1.3 Liter D13
D13B1
1988-1991 Honda Civic DX (European Market)
Displacement : 1343 cm³
Bore and Stroke : 75 mm X 76 mm
Compression : 9.5:1
Power, Torque : n/s (Not stated in Owners Manual)
Valvetrain : SOHC, 4 valves per cylinder
Fuel Control : Single Carburetor
D13B2
1992-1995 Honda Civic DX (European Market)
Compression : 9:1
Power, Torque : 75 hp (56 kW) @ 6300 rpm
D13B4
1998-2003 Honda City EXI/DX
Displacement : ????
Bore and Stroke: ????
Compression : ????
Power, Torque : 70 kW (95 HP) at 6.500 min−1
Valvetrain : SOHC
Fuel Control : Multi-point fuel Injection, PGM-FI
D13B7
1998-2001 Honda Logo 5D
Displacement : ????
Compression : ????
Power, Torque : ????
Valvetrain : SOHC
D13C (no specs, will update)
1.4 liters D14
D14A1
1987-1991 Honda Civic GL and 1990 CRX (European Market)
Displacement : 1396 cm³
Bore and Stroke : 75 mm X 79 mm
Compression : 9.3:1
Power, Torque : 90 hp (90 bhp) @ 6300 rpm, 112Nm @ 4500 rpm
Valvetrain : SOHC, 16 valves
Fuel Control : Dual Carburetor
D14A2
1995-1996 Honda Civic MA8 (European Market)
Bore and Stroke : 75.0 mm X 79.0 mm
Compression : 9.2:1
Torque, Power : 117 Nm @ 5000 rpm, 66 kW @ 6100 rpm
1.5 liter D15
D15A2
1984-1987 Honda CRX DX ;1984-1987 Honda Civic (JDM)
Displacement : 1488 cm³
Bore and Stroke : 74 mm X 86.5 mm
Compression : 9.6:1
Power : 76 hp (57 kW) @ 5500 rpm & 84 ft·lbf @ 3500 rpm
Valvetrain : SOHC 3 valves + 1 auxiliary valve for each cylinder
Fuel Control : Carbureted, CVCC, CVCC was not equipped on Canadian CDM cars
Known as the EW-2 from 84-86
D15A3
1985-1987 Honda CRX Si and 1987 Civic Si (AU/NZ)
Displacement : 2005 cm³
Compression : 8.7:1
Power : 108 hp (81 kW) @ 5500 rpm & 100 ft·lbf @ 4500 rpm
Valvetrain : SOHC, 3 valves/cylinder
Fuel Control : pgm-fi2
D15B - First d-series engine to use Vtec
1991-1999 Honda Civic VTi EG4 (Japanese Market)
1992-1998 Honda CRX VXi EG1 (Japanese Market)
Displacement : 1493 cm³
Bore and Stroke : 75 mm X 84.5 mm
Rod Length : 137 mm
Compression : 9.3:1
Power : 130 hp (97 kW) @ 5800 rpm & 102 ft·lbf (14.1kg/m) @ 5200 rpm
Redline : 7200 rpm
Fuel Cut : 7411 rpm
Valvetrain : SOHC VTEC
Head Code : P08
Fuel Control : OBD-1 MPFI
D15Z7 - Same engine build as D15B with stage 3 Vtec
1996-1999 Honda Civic VTi EK3 and Ferio Vi
Rod Length : 137 mm
Compression : 9.6:1
Power : 130 hp (97 kW) @ 7000 rpm & 102 ft·lbf (14.2kg/m) @ 5300 rpm
Fuel Control : OBD-2 MPFI
D15B1
1988-1991 Honda Civic Hatchback
Bore and stroke : 75 mm X 84.5 mm
Compression : 9.2:1
Power : 71 hp (53 kW) @ 5500 rpm & 82.6 ft·lb @ 3000 rpm [1]
Valvetrain : SOHC (4 valves per cylinder)
Fuel Control : OBD-O DPFI
D15B2 - This engine was the d15b1 build minus the restrictor plate between the throttle body and the intake header
1988-1991 Honda Civic GL/DX/DLX
1988-1991 Honda CRX DX
1992-1995 Honda Civic LSi Hatch/Saloon (European Market)
1990-1995 Honda Concerto (European Market)
Compression : 9.2:1
Power : 92 hp (69 kW) @ 6000 rpm & 119 Nm @ 4500 rpm
Cam Gear : 38 tooth
Fuel Control : PGM-FI Dual Point (OBD0)
Redline : 7000 rpm (6000 rpm honda concerto)
D15B3
1988-1995 Honda Civic EX
1988-1995 Honda Civic Shuttle GL
Compression : 9.9:1
Cam Gear : 38 tooth
Fuel Control : Carburetor
D15B4
1989-1991 Honda Civic GL (Australian Market)
Compression : 9.2:1
Power : 90 hp (70 kW) @ 5200 rpm & 122 Nm @ 3800 rpm
Valvetrain : SOHC (2-4 valves per cylinder, depending on year)
D15B6
1988-1991 Honda CRX HFx
Compression : 9.1:1
Power : 62 hp(88-89) 72 hp(90-91)@ 4500 & 83 ft·lbf @ 2800 rpm
Valvetrain : SOHC (2 valves per cylinder)
Fuel Control : OBD-0 MPFI
D15B7 - same engine build as the d15b8 while D15b7 focuses on low end power and the d15b8 on high end power
D15B7
Originally Posted by RedRevolver
* Found in:
o 1992-1995 Honda Civic CX (Canadian model)
o 1992-1995 Honda Civic DX/LX
o 1993-1995 Honda Civic del Sol S
o 1992-1995 Honda Civic LSi Coupe (European Market)
+ Displacement : 1493 cm³
+ Bore and Stroke : 75 mm X 84.5 mm
+ Compression : 9.2:1
+ Power : 105 hp (78 kW) @ 6200 rpm & 98 ft·lbf @ 3800 rpm
+ Valvetrain : SOHC (4 valves per cylinder)
+ Piston Code : PM3
+ Fuel Control : OBD-1 MPFI
D15B8
1992-1995 Honda Civic CX (U.S. model)
Displacement : 1500 cm³
Compression : 9.1:1
Power : 70 hp (52 kW) @ 4500 rpm & 83 ft·lbf @ 2800 rpm
D15Z1 - First d-series engine to use VTEC-E (type of VTEC focused around gas mileage rather than high power and speed)
1992-1995 Honda Civic VX
1992-1995 Honda Civic VEi (European Market)
Rod Length : 137 mm
Compression : 9.3:1
Power : 92 hp (69 kW) @ 5600 rpm & 97 ft·lbf @ 4800 rpm
Valvetrain : SOHC VTEC-E (4 valves per cylinder)
Piston Code : P07
D15Z4
1996-2000 Civic Exi and SA Ballade & Civic 150i
Displacement : 1493 cm3
Power : 90HP and 105HP(82Kw) @ 5800 rpm
Torque (ft·lbf@rpm): 99 (140 N·m) @ 4200 rpm
Valvetrain : SOHC non-VTEC 16v
D15Z6 - used VTEC-E
1995-1997 Honda Civic 1.5 iLS (European Market)
Rod Length : 137 mm
Compression : 9.6:1
Power : 115hp @ 6500 rpm
Torque : 100 ft·lbf (141 Nm) @ 4800 rpm
VTEC Switchover : 2500 rpm
Fuel Control : PGM-FI MPFI
D15Z8- VTEC-E
1997-2000 Honda Civic LS (European Market)
Compression : 9.6:1
Power : 84 kw (114 hp) @ 6500 rpm
Torque : 134 Nm (95 ft·lbf) @ 5500
1.6 liter D16
D16A1
1986-89 Acura Integra (USA)
Displacement : 1590 cm³
Bore and Stroke : 75 mm X 90 mm
1986-1987 Compression : 9.3:1 1988-1989 Compression : 9.5: 1
1986-1987 Power : 113 hp (84 kW) @ 6250rpm Torque : 99 ft·lbf @ 5500rpm
1988-1989 Power : 118 hp (88 kW) @ 6250rpm Torque: 101 ft·lbf @ 5500rpm
Valvetrain : DOHC
Piston Code 1986-87 : PG6
Piston Code 1988-89 : P29 (PM7 is ZC equivalent/same piston)
D16A3
1986-89 Acura Integra (Australia)
Compression : 9.5:1
Power : 118 hp (88 kW) @ 5600 rpm & 103 ft·lbf @ 4800 rpm
Valvetrain : DOHC
D16A6 - Also called D16Z2
1988-1991 Honda Civic Si, CRX Si, Civic Wagon RT4WD
1990-1991 Honda Civic EX Sedan
1988-1995 Honda Civic Shuttle RT4WD (UK/Europe/Asia/AU/NZ)
1989-1996 Rover 216/416 GSi (UK/Europe)
Compression : 9.1:1
Power : 115 hp (86 kW) @ 5600 rpm & 100 ft·lbf @ 3,800 rpm, redline 7200 rpm (USA)
Note: 1988 engines were 105 hp (78 kW), MY89-91 hp was increased to 108
Valvetrain : SOHC
Fuel Control : OBD-0 four-point PGM-FI
D16A7 - this engine is basically a D16A6 that came without a catalytic converter
88-95 Models in South Africa
Ballade SH4 and SR4 ( D16A7 / EE4 )
Compression : 9.6:1
Power : 115hp @ 5900 rpm & 100ft·lbf @ 4800 rpm
Valvetrain : SOHC
Fuel Control : OBD-0 Multi-point PGM-FI
D16A8
1988-1995 Civic/CRX/Concerto (UK/Europe/Australia)
1990-1995 Rover 216/416 GTi(UK/Europe)
Compression : 9.5:1
Power : 124 hp (92 kW) @ 6800 rpm & 108 ft·lbf @ 5900 rpm
Valvetrain : DOHC
D16A9 - basically a D16A8 without the cat converter
1988-1991 Concerto (UK/Europe)
1988-1991 CRX 1.6i-16(UK/Europe/South Africa)
1988-1991 Civic 1.6i-16(UK/Europe/South Africa)
1989-1996 Rover 216/416 GTi (UK/Europe)
1992-1995 Civic Si (Peruvian version)
Compression : 9.5:1
Power : 130hp @ 6800 rpm & 108 ft·lbf @ 5900 rpm
Valvetrain : DOHC 16v
Redline: 7200RPM
Limit: 8000RPM
D16W7
Vtec-E
Found in:
2005-2007 Honda Civic Vti-L/ Vti (Singapore)
Displacement:1590 cm3
Compression : 10.9:1
Power : (*160) hp (130 kW) @ 7800 rpm & 108 ft·lbf @ 7900 rpm
Valvetrain : SOHC
Redline 8600RPM
Limit 8900RPM
Also found in 2001-2005 Honda Civic (Europe)
Same as above, except:
Power: 110hp (81kW) @ 5600 rpm & 152 Nm @ 4300 rpm
Redline 6100rpm
Limit 6200rpm
D16Y3
1995-1997 Honda Civic MB1 LS (UK/Europe)
Power : 115 hp (86 kW) @ 5600 rpm, redline 6500 rpm
Valvetrain : SOHC
D16Y4
1996-2000 EK1 Civic CXi,GL,GLi (Australia)
Displacement: ????
Power: 88Kw
Vavletrain: SOHC
D16Y5 - VTEC-e
1996-2000 Honda Civic HX
1996 Honda Civic EX(sedan Peruvian version)
Compression : 9.4:1
Power : 115 hp (86 kW)@ 5600 rpm & 104 ft·lbf @ 4500 rpm
1996-2000 VTi (Phils. & NZ)
Compression :
Power : 127 hp (95 kW)@ 5800rpm
Head Code : P2J
ECU Code : P2M
Piston Code : P2MY
D16Y7
1996-2000 Honda Civic DX/VP/LX/CX hatchback
1999 Honda Civic Special Edition - SE(Canada)
1996-97 Honda del Sol S
Displacement : 1593 cm³
Compression : 9.4:1
Power : 106hp @ 6400 rpm
Torque (ft·lbf@rpm): 103 @ 4,600 rpm
RPM Redline : 6800 rpm 7200 gov. kicks in
Valvetrain : SOHC 16 valves
Fuel Control : OBD2 MPFI
D16Y8 - VTEC
1999-2000 Honda Civic SE 1.6 Vtec (UK)
1997-1998 Honda Civic EX Sedan
1996-1998 Honda Civic EX Coupe
1996-2000 Honda Civic EX (USDM)
1996-2000 Honda Civic SI (Canada Only)
1997-2000 Acura 1.6EL (Canada Only)
1996-1997 Honda del Sol Si
Compression : 9.6:1
D16Y8 1.6 16V SOHC VTEC PGM-FI 1590
127 hp@6600 rpm 108tq@5500 rpm
Redline 6900 rpm
D16Y9
1996-2000 Honda Ballade,venezuela and Civic in South Africa
Compression : 9.2:1
Power, Torque : {{Auto hp120 / 89kw} @ 5900 rpm 146nM @ 4000 rpm
Valvetrain : SOHC, 4 valves per cylinder non - VTEC
D16Z5 - Basically the same engine as the D16A9, but now with a catalytic converter and lamda sensor
1988-1992 Honda CRX (European Market)
Compression : 9.5:1
Valvetrain : DOHC
Cam Gear : 34 tooth
Fuel Control : OBD-0 PGM-FI
D16Z6
1991-1992 Honda civic si
1992-1995 Honda Civic EX, EX-V and SI
1992-1995 Honda Civic ESi (European Market)
1993-1995 Honda Del Sol Si (only USDM)
1993-1995 Honda Del Sol ESi (European)
Compression : 9.2:1
Power : 125 hp (93 kW) @ 6600 rpm & 106 ft·lbf @ 5200 rpm
Redline : 7200 rpm
Fuel Cut : 7411 rpm
D16Z9
1994-1995 Civic Coupe (EJ1) 1.6i Esi European
Compression : 9.2:1
Redline : 7200 rpm
Fuel Cut : 7411 rpm
1.7 liters D17
D17A1
2001-2005 Honda Civic DX/LX/VP v-tec
Displacement : 1668 cm³
Bore and Stroke : 75 mm X 94.4 mm
Compression : 9.5:1
Power : 115 hp (86 kW) @ 5600 rpm & 110 ft·lbf @ 4500 rpm
Valvetrain : SOHC
D17A2 - VTEC
2001-2005 Honda Civic EX
2001-2005 Honda Civic Si (Canada only)
2001-2005 Acura 1.7 EL (Canada only)
Bore and Stroke : 74.98 mm X 94.4 mm
Compression : 9.9:1
Power : 127 hp @ 5800 rpm & 114 ft·lbf @ 4800 rpm
Valvetrain : SOHC VTEC (Single Cam)
D17A5 - VTEC
SOHC VTEC
Found in :
2004-2005 HONDA CIVIC VTi & VTi-S (INDONESIA), EX (Brazil)
2004-2005 HONDA STREAM (INDONESIA)
DISPLACEMENT : 1668 cm³
BORE N STROKE : 74.98 mm X 94.4 mm
COMPRESSION RATIO : 9.5:1
POWER : 130 HP @6500 RPM & 165 NM @ 4500 RPM
D17A6 - same as d17a5 but with VTEC-E instead of VTEC
2002-2005 Honda Civic HX
Compression : 9.5:1
Power : 125 hp (93 kW) @ 5800 rpm & 111 ft·lbf @ 3800 rpm
Valvetrain : SOHC VTEC-Ec
D17A7
2004-2005 Honda Civic GX
Uses CNG (Compressed Natural Gas)
Compression : 12.5:1
Power : 115 @ 5800 rpm & 98 ft·lbf @ 3800 rpm
Valvetrain : SOHC
Any info on the ZC would be greatly appreciated. I will update this thread as I find more knowledge.
Originally Posted by Grandtheftlunchbox
DOHC ZC Specs.
1.6L (1590 cc) DOHC
130-137 hp @ 6800 rpm
Bore 75.0
Stroke 90.0
C.R. 9.5:1 I can find no evidence of it being any higher than this.
91 octane. Some have reported no problems with 87, but the specified gas is 95 and/or 96 RON, which is equal to 91-92 'pump octane' available in the US.
Modified by austinkli at 7:19 AM 7/1/2008
Modified by austinkli at 7:23 AM 7/1/2008
Old Jun 30, 2008 | 08:36 PM
rSol93's Avatar
should have just linked them to wikipedia.
Old Jun 30, 2008 | 08:38 PM
austinkli's Avatar
Default Re: (rSol93)
a good bit of it came from wikipedia, some of it i had to search for. Besides, then I can't update it when I find new info. I plan on doing a lot more tomorrow, for now, it's almost 12 in my timezone, time for sleep. Please post any knowledge so I can add it tomorrow.
Old Jun 30, 2008 | 08:47 PM
RedRevolver's Avatar
Default Re: (austinkli)
uhh you must not have looked at wiki very well cuz you got the D15B7 messed up, heres what wiki has:
D15B7
* Found in:
+ Piston Code : PM3
I dunno what else you might have gotten wrong but i know that one cuz its what I have in my car and like hell i have 72hp lol
Old Jul 1, 2008 | 04:43 AM
grandtheftlunchbox's Avatar
Default Re: d-series engine (austinkli)
SOME INFO FOR ZC's
Here's some info on the DOHC ZC taken from thezcr.com:
1st gen DOHC ZC - brown valve cover - came in 86-87 JDM Integra - will bolt directly into 1st gen CRX Si and 3rd gen Civic Si - will not bolt directly into 2nd gen CRX or 4th gen Civic.
2nd gen DOHC ZC - black valve cover - came in 88-89 JDM Integra - will bolt directly into 1st gen CRX and 3rd gen Civic, same as brown valve cover, however, it uses electronic advance distributor like 88-89 USDM Integra D16A1 - 1st gen CRX Si and 3rd gen Civic Si have vacuum advance distributor, so, to use it on 1g CRX or 3g Civic, you will have to do a lot of wiring changes.
3rd gen DOHC ZC - black valve cover - came in 88-91 JDM CRX Si and Civic Si - bolts directly into 2nd gen CRX and 4th gen Civic.
4th gen DOHC ZC - black valve cover - came in several different models of JDM cars 92 & up - is OBD1 - has Cylinder Position Sensor inside the distributor and will bolt directly into 92-00 Civics
SOHC ZC - basically the same as D16A6 (little more horsepower) - will bolt directly into 2nd gen CRX and 4th gen Civic.
SOHC VTEC ZC - basically the same as D16Z6 - OBD1 - will bolt directly into 92-00 Civic
DOHC ZC Specs.
1.6L (1590 cc) DOHC
Bore 75.0
Stroke 90.0
Old Jul 1, 2008 | 06:17 AM
austinkli's Avatar
Default Re: (RedRevolver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedRevolver &raquo;</TD></TR><TR><TD CLASS="quote">uhh you must not have looked at wiki very well cuz you got the D15B7 messed up, heres what wiki has:
D15B7
* Found in:
+ Piston Code : PM3
thought I pulled that one from wiki, I should have noticed that because I have that engine too. hmm... Guess I was more tired than I thought. Thanks for the knowledge, I fixed it.
AngelMarieB
Jul 31, 2017 03:36 PM
ThriLlz_
24
Jun 2, 2006 09:32 AM
trbo823
Jun 21, 2003 03:08 PM
andwrong
Dec 28, 2002 01:02 PM
Pele
13
Sep 19, 2002 06:58 AM
