Dpfi to Mpfi swap, need serious help,! HELP
Old Jun 30, 2008 | 01:26 PM
EtherEG93's Avatar
Default Dpfi to Mpfi swap, need serious help,! HELP
im doing a mpfi swap
and my b12 pinout going into my ecu, has a white with red stripe wire coming out of it, i searched all dp-mp posts and it says my car should not have a wire coming from b12
its a 91 dx ecu says 11/28/91 for the date
should i cut this and wire it as ....
B12
White
crank Angle Sensor
or what is up?
i have the correct pinouts counting over, because ive checked colors, left to right, and i still have a white with red wire in b12
i need help somebody help, this is my only car
Thanks
Modified by EtherEG93 at 7:42 PM 6/30/2008
Old Jun 30, 2008 | 01:56 PM
low91rex's Avatar
Default Re: Dpfi to Mpfi swap, need serious help,! HELP (EtherEG93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EtherEG93 &raquo;</TD></TR><TR><TD CLASS="quote">
B12
White
crank Angle Sensor
Thanks</TD></TR></TABLE>
Yes.
Some dx ECU's have a wire there and some don't.
Old Jun 30, 2008 | 06:44 PM
EtherEG93's Avatar
got it running, now but my FITV is not hooked up
the plug is square and my engine harness plug for the dp one is round,
does anyone know which wires go to where? theres 2 from each plug
Thanks
Old Jun 30, 2008 | 06:45 PM
immorality's Avatar
Default Re: Dpfi to Mpfi swap, need serious help,! HELP (low91rex)
I ran into the same problem, just use it as needed for the swap.
Old Jun 30, 2008 | 09:08 PM
NHswaps13203's Avatar
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
Default Re: Dpfi to Mpfi swap, need serious help,! HELP (immorality)
im pretty sure thats not the fit valve could be wrong, anyway the wires are reversable
Old Jul 3, 2008 | 06:15 PM
EtherEG93's Avatar
i wired it in and it seemed to help, no codes, but when i pull up to a red light or stop sudden it takes awhile for my idel to drop down from 2k to 1k for example
any ideas?
smitri1213
Jun 3, 2013 03:25 PM
Atomic_EF9
May 14, 2011 04:00 PM
zoomspeed05
May 7, 2007 05:31 PM
mr. carpenter
Jul 25, 2003 11:16 PM
jisecup
Jul 9, 2003 02:53 PM
