93 SE - SRS light on
Old Jun 30, 2008 | 05:43 AM
vic_houston's Avatar
Default 93 SE - SRS light on
I have a 93 accord, SE (136K, auto tranny). Yesterday I saw the SRS light come on, then go away on its own (while driving). In the evening it did the same, though it was flickering (going on-off).
I don't have the manual for this car, but what is SRS (supplemental restraint system) and what can i do about this problem.
Thanks for the help.
Old Jul 5, 2008 | 08:02 AM
DVF2001's Avatar
Default Re: 93 SE - SRS light on (vic_houston)
O.K., here is the DIY for resetting the memory for your SRS Light. Your SRS Light may trigger and remain illuminated for several reasons. Some of which are:
Unplugging your gauge cluster
Unplugging your SRS harness(es) when you remove your seats
Unplugging any other SRS plugs and turning your ignition on
This DIY is intended ONLY for resetting your SRS Indicator Light when it is triggered for the reasons listed above. Your SRS Light may indicate a more serious problem that should be evaluated by your local Authorized Honda/Acura Technician. Remember, that airbag may save your life or the life of someone you care about so don't disregard that indicator light unless you are sure that it triggered for some other reason. That being said, here are some pics and instructions for resetting the SRS Light (note: These pics are from a 6th Gen Accord EX Coupe 4AT. The MES plug may be located in a different location on other models. Make sure you know what you are unplugging. There are no contacts inside the port that the MES Plug plugs into.)
Tools needed:
Flashlight (if needed to search for MES Plug under dash)
2 1/2 ft. piece of small gauge speaker wire (insulation stripped off ends)
(1) Locate MES Plug. It should be located near the driver's side fuse panel under the dash. The harness is yellow with two wires.
(2) Unplug the MES Plug. It should look like this.
(3) Insert one end of speaker wire into MES Plug (one wire in each contact)
(4) Follow this sequence of shorting the other two leads of the speaker wire and turning the ignition to "on" (not accessory, not start)
-Short and hold the leads while you turn the ignition to on. The SRS Light will illuminate for a few seconds then go off.
-When the SRS Light goes off, unshort the wires. The SRS Light will come back on.
-Short and hold the wires again. The SRS Light will go off.
-When the SRS Light goes off, unshort the wires. The SRS Light will blink twice.
-Turn the ignition off.
-Start engine as normal. The SRS Light should illuminate for a couple of seconds as normal and then go off.
(4a) This series of shorting/unshorting needs to take place within a 4 second window of the SRS Light going on/off each time.
Old Jul 5, 2008 | 11:54 PM
stereo69's Avatar
theres no reset on the 93 accord sounds like a loose connection or somthing as on the 93 the system does a self check if the problem is gone the light just goes out!
jhaag115
Aug 8, 2009 12:41 AM
wardseg6
Honda Civic (2001 - 2005)
Jul 21, 2007 11:40 PM
Caveman74
Oct 30, 2006 02:55 PM
