Proper Valve Adjustment Location!
Old Jun 29, 2008 | 09:17 PM
JakeSpec's Avatar
Default Proper Valve Adjustment Location!
Tired of seeing people adjusting thier valve's in the wrong location? I freakn am so i made a quik diagram on photshop for you kids that keep adjusting in between the rocker adjuster and actual valve and not in between the cam lobe and rocker
argggggggggggggggggggggggghhhhhhhhhhhhhhhhhhhhhhhh hhh!!!!!
6/ intake 7/ exhuast on all OEM cams including R's
7/ Intake 8/ Exhaust For after market large lift race cams
Here ya go
dont forget your speacial tool from the snap on guy or this might be a lilttle ruff
Good Luck
Old Jun 29, 2008 | 09:55 PM
A.E Motoring's Avatar
Default Re: Proper Valve Adjustment Location! (JakeSpec)
good job buddy, thats the way i always adjust my valves
Old Jun 29, 2008 | 11:18 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Proper Valve Adjustment Location! (A.E Motoring)
who the hell sets the lash at the adjustent screw?? You would think if you're bright enough to adjust them then you're bright enough to do it right.
Old Jun 29, 2008 | 11:49 PM
MOE@Hyper16Valve's Avatar
Default Re: Proper Valve Adjustment Location! (DCFIVER)
In the pic i only see 4 valve springs on the exhaust side what the???
Old Jun 30, 2008 | 04:18 AM
GhostAccord's Avatar
Default Re: Proper Valve Adjustment Location! (MOE@Hyper16Valve)
Honestly I've never seen it done between the rocker and cam lobe. Guess I'll have to try this out next time I set mine. I've never had any problems doing it between the valve stem and adjustment screw.
I would like to know the reasoning / theory for doing it this way?
Any document that I have read related to this procedure states to place the feeler gauge between the adjustment screw and valve?
Old Jun 30, 2008 | 04:54 AM
Runnerdown's Avatar
Default Re: Proper Valve Adjustment Location! (GhostAccord)
Rocker ratio is why, lash will be way different @ the valve tip.
K-series are measured between the adjuster and valve tip but not b or h series.
Old Jun 30, 2008 | 05:13 AM
Default Re: Proper Valve Adjustment Location! (Runnerdown)
Ah good to know.
That would be why I've never seen it demonstrated that way, I'm used to the F series.
Old Jun 30, 2008 | 06:19 AM
flyrod's Avatar
I think the B18 LS and H23 heads are also measured between the cam and rocker.
Old Jun 30, 2008 | 06:45 AM
slambedcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MOE@Hyper16Valve &raquo;</TD></TR><TR><TD CLASS="quote">In the pic i only see 4 valve springs on the exhaust side what the???</TD></TR></TABLE>
i thought the same thing, but if you look into #3 there is the top of an adjusting screw.
Old Jun 30, 2008 | 07:30 AM
JakeSpec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">Rocker ratio is why, lash will be way different @ the valve tip.
K-series are measured between the adjuster and valve tip but not b or h series.</TD></TR></TABLE>
Old Jun 30, 2008 | 07:31 AM
JakeSpec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCFIVER &raquo;</TD></TR><TR><TD CLASS="quote">who the hell sets the lash at the adjustent screw?? You would think if you're bright enough to adjust them then you're bright enough to do it right.</TD></TR></TABLE>
dude ive seen it here too many times i just had to set the record straight!
youll see watch!
Old Jun 30, 2008 | 07:59 AM
AllMotorRandy's Avatar
any reason why it needs to be checked on the backside of the rocker and not the front?
Old Jun 30, 2008 | 08:15 AM
JakeSpec's Avatar
Default Re: Proper Valve Adjustment Location! (AllMotorRandy)
its easier to adjust screw when there is no valve lash in the way no particular reason just my preference been doing it like that for like 9 years
Old Jun 30, 2008 | 08:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeSpec &raquo;</TD></TR><TR><TD CLASS="quote">its easier to adjust screw when there is no valve lash in the way no particular reason just my preference been doing it like that for like 9 years</TD></TR></TABLE>
oh okay.... lol..... i thought i was doing something wrong all these years!
Old Jun 30, 2008 | 08:55 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhostAccord &raquo;</TD></TR><TR><TD CLASS="quote">Honestly I've never seen it done between the rocker and cam lobe. Guess I'll have to try this out next time I set mine. I've never had any problems doing it between the valve stem and adjustment screw.
Any document that I have read related to this procedure states to place the feeler gauge between the adjustment screw and valve?</TD></TR></TABLE>
Accord motors are not the same. The service procedures for Accord motors is to adjust the lash at the adjustment screw. But for DOHC honda motors it should be done at the cam. So you were doing it correct with your accord motor. (Any documents stating other wise are false.)
Old Jun 30, 2008 | 09:44 AM
B16SolMan's Avatar
New User
D series also call for the adjustment to be made between the valve stem and the adjustment screw.
Old Jun 30, 2008 | 11:11 AM
acydphryck's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotorRandy &raquo;</TD></TR><TR><TD CLASS="quote">
oh okay.... lol..... i thought i was doing something wrong all these years! </TD></TR></TABLE>
you have been...your motor is still not running LOL!!!! jk dude...where you been at???
Old Jun 30, 2008 | 11:49 AM
IanB's Avatar
Huh, good info! I've only ever done it on the D-series, but I'll be making the jump to B soon, so this will come in handy.
I can assume it is done the same regardless of whether the head has vtec or not?
Old Jun 30, 2008 | 11:16 PM
Thrizzle's Avatar
* B A N N E D *
Default Re: (IanB)
I put the feeler gauge there and adjust the screw till it feel "right", lock it.... then slide the feeler back and forth to see if it has the right about of "drag/resistance" then off to the next.
Old Jul 7, 2008 | 09:12 AM
JakeSpec's Avatar
Bump for Drunk Kids!
Old Jul 17, 2008 | 11:35 AM
JakeSpec's Avatar
definetly Drunk
mhewitt
Sep 16, 2010 10:51 AM
alcarp
Mar 4, 2010 05:15 PM
Dat_One_Si
Sep 23, 2006 07:43 PM
Footwork
12
Jun 14, 2003 01:41 AM
3rdGteg
Dec 22, 2001 11:02 AM
