MPFI wiring problems
I'm in the middle of swapping a B18a into my 1990 DX. The problem is, it was originally an automatic. So I'm converting to manual AND MPFI.
I've already followed the guides to convert auto -> manual, but now I need to do the mpfi wiring work. Can I use the original auto wiring harness and ignore the auto wires?
According to this: http://www.fourthgenhatch.net/mpfi.html pin B11 is wired to the shifter position switch, D4.
Since I'll be using a manual ECU, I'm assuming that the "shifter position switch" is a auto only thing and won't matter, but I need to make sure before I hack up the wiring.
Modified by ZAKU at 9:47 PM 6/29/2008
I figured as much, I'm just stupid when it comes to electrical work so I needed to make sure.
But you better be right, or I'll fly down to CA and kick your ***
vietnamezerice
Sep 24, 2008 09:18 PM
