Rear discs on a del sol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khallilD »</TD></TR><TR><TD CLASS="quote">Same thing as a rear disk conversion on a Civic, except you'll need Del Sol Si or Del Sol VTEC ebrake cables.
yeah that's true.. my bro an I did a convertion on his del sol from a integra .. i think it was a 94 or something .. also did one to my crx,, that crx was automatic ,, we swap it to manual and convert the rear drum to disc.. also from a integra.. it works... just that the caliper has to be from the same crx .. and the del sol from the same del sol.. otherwise the brake cables are not going to fit into the integra caliper.. correct me if i'm wrong cuz i couldn't use the integra calipers .....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sorullo »</TD></TR><TR><TD CLASS="quote">
You could, but you needed the correct ebrake cables. All 88-00 Civic and 90-01 Integra rear calipers are the same.
</TD></TR></TABLE>You could, but you needed the correct ebrake cables. All 88-00 Civic and 90-01 Integra rear calipers are the same.
h22acd5
Jul 26, 2009 06:09 PM
Eg2707
Dec 21, 2006 12:45 PM
94redintegra
Dec 25, 2005 10:31 AM
