Soldering Fuel Pump Relay
Old Jun 29, 2008 | 06:57 PM
dubs97integ's Avatar
Default Soldering Fuel Pump Relay
Alright, I did a B16 swap and it ran for 5 minutes before if shut off. I have full power, but I dont hear the fuel pump relay click or fuel pump prime. I have been reading about the relays going out a lot. I picked one up at the junkyard and still no clicking. So I read you can solder the contacts but I dont know which ones or where? Ive been trying to find pics but no luck. Any help would be appreciated. Thanks in advance.
Old Jun 29, 2008 | 08:53 PM
black0hatch's Avatar
Default Re: Soldering Fuel Pump Relay (dubs97integ)
you might have other problems but have you tried taking it apart? ive never had to do it but i would imagine if you had it apart just look real closely at all the solders you should see a cracked one and then fix it.
Old Jun 29, 2008 | 09:06 PM
acmoc's Avatar
Default Re: Soldering Fuel Pump Relay (black0hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black0hatch &raquo;</TD></TR><TR><TD CLASS="quote">you might have other problems but have you tried taking it apart? ive never had to do it but i would imagine if you had it apart just look real closely at all the solders you should see a cracked one and then fix it.</TD></TR></TABLE>
yep you just reinforce the weak ones
Old Jun 30, 2008 | 06:53 PM
Well, I did take it apart and i dint see any cracks on the soldering so maybe I do have another problem on my hands but I will resolder them to see if it helps at all. Any other suggestions?
Old Jun 30, 2008 | 06:55 PM
you have to look really really close. like i said ive never done it on a main relay but on a miata i had the blinker relay had a broken solder the first time i took it apart i didnt see any cracks i had to sit there with a good light and stare at it for a while. are you sure your not getting fuel? did you try cracking a line loose to see if fuel comes out?
Old Jul 1, 2008 | 05:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black0hatch &raquo;</TD></TR><TR><TD CLASS="quote">you have to look really really close. like i said ive never done it on a main relay but on a miata i had the blinker relay had a broken solder the first time i took it apart i didnt see any cracks i had to sit there with a good light and stare at it for a while. are you sure your not getting fuel? did you try cracking a line loose to see if fuel comes out?</TD></TR></TABLE>
Yea all the soldering looks good. I found the solution...FUSE#14! Piece of crap must of burnt out. I believe its for alternator. So everything is cool now thanks HT
zippakilla
Feb 6, 2009 04:01 AM
crazyimport
Sep 2, 2008 09:22 AM
kaychi
Mar 28, 2007 03:56 PM
93FlatBlackHatch
Dec 30, 2006 03:22 PM
flat-blk-HB
Aug 24, 2005 07:36 PM
