car dies when a/c is turned on.
Old Jun 29, 2008 | 06:12 PM
musclehead954's Avatar
Default car dies when a/c is turned on.
after getting my eg from paint in miami, i hit the a/c and the thing died on me. popped the clutch and got it running w/o stopping, but the phrase "in the ghetto" popped into my mind. my a/c hasnt been serviced, well, ever. would that solve the problem?
and wth happened to NOFX? why was she banned?
Old Jun 29, 2008 | 06:29 PM
z6hatchboy's Avatar
Default Re: car dies when a/c is turned on. (musclehead954)
Did it sqeal any when it died, when you hit the switch? Thats a odd thing to happen, only thing i can thing is that the compressor is trying to lock up? I i/m'd you about NOFX.
Old Jun 29, 2008 | 06:37 PM
Default Re: car dies when a/c is turned on. (z6hatchboy)
[QUOTE=z6hatchboy]Did it sqeal any when it died, when you hit the switch? Thats a odd thing to happen, only thing i can thing is that the compressor is trying to lock up? QUOTE]
i didnt hear anything over my music and my noisy axle. so idk. i moved the tab over and then it died.
Old Jun 29, 2008 | 06:43 PM
baller status's Avatar
Are you idling low? There's an AC idle up circuit, if it's uplugged, the AC will bog your car down and you could stall. Make sure the AC pulley isn't seized.
Old Jun 29, 2008 | 06:45 PM
Default Re: car dies when a/c is turned on. (baller status)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baller status &raquo;</TD></TR><TR><TD CLASS="quote">Are you idling low? There's an AC idle up circuit, if it's uplugged, the AC will bog your car down and you could stall. Make sure the AC pulley isn't seized.</TD></TR></TABLE>
my idle roams bc of a vac leak i have. damaged head gasket. ill check the a/c pully. that might be it. hell, i might even remove the whole unit since i never use it.
Old Jun 29, 2008 | 07:08 PM
ive almost gotten my eg back to stock specs; just need a new pre cat 02 sensor, new HG, and put my stock head and IM back on. then a new pair of axles so i dont have to listen to the RRRRrrrrrRRRR of my bad cv joint. just need the time to get it all done.
the a/c just happened to be an inconvenience considering it was 102 degrees that day.
Christa Long
Feb 22, 2017 01:14 PM
v-tec23
Aug 19, 2009 10:12 AM
nafreak
Apr 16, 2009 12:09 PM
azazello
16
Aug 2, 2008 08:49 PM
