*Do-It-Myself* Buffing 2002 Accord Headlights
A little bored today, decided to make a DIY. For those with foggy headlights, there is help. Follow these steps and it should hopefully work. Sorry bout the crappy camera, but its the best i can do.
Materials:
*Sandpaper
320 grit
400
600
800
1000
2000
*Water applicator
Sponge?
Spray Bottle?
etc...
*Buffers
Rubbing Compound
Applicator Pad
Microfiber towels (recommended)
or cotton towels
My fogged headlights err w/e that stuff is on there
Depending on how bad your headlights are you may want to start off with a lower grit, if not you may use something smoother, i started with 320 because that was some thick stuff
For those of you show don't know, wetsanding works best whenit comes to buffing anything. Wetsanding is basically sanding while keeping the area wet and clean of debri.
Make sure you do a thorough job when using each grit to get out all the scratches.
Just keep sanding and work your way up. I just skipped 400 and 800, for theyre not very necessary unless youre a perfectionist, i was just too lazy
After 1000
Then 2000
All done sanding and dried
Rubbing compound does miracles
Applied on my meguiars applicator pad & compare
Sorry no pics of buffing, but just make sure youre tough with it, really rub it in. After completed buffing use the microfiber or cotton towel and wipe clean.
After all is said and done ***Voila***
Any questions feel free to ask
Modified by MugenEH3 at 7:10 PM 6/29/2008
Materials:
*Sandpaper
320 grit
400
600
800
1000
2000
*Water applicator
Sponge?
Spray Bottle?
etc...
*Buffers
Rubbing Compound
Applicator Pad
or cotton towels
After 1000
Then 2000
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UCLA.lion »</TD></TR><TR><TD CLASS="quote">do not do this if you have plastic headlights, only glass!
Plastic will just fog up when sanded and cannot be buffed out.
Wrong.
https://honda-tech.com/zerothread?id=1769562
Wrong.
LOL
finally, someone that knows how to restore headlights
LOL
yeah, that and, the funniest thing about it is that the pictures show he sanded a plastic headlight and buffed it out haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TsujenDB1 »</TD></TR><TR><TD CLASS="quote">Or ya could have used this and got the same/better results + an hour of your time back
obviously you've never used it, because that stuff SUCKS! you need to apply it like 20 times and it still doesn't get it completely off, it comes right back after like 5 days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRIUS »</TD></TR><TR><TD CLASS="quote">
Wrong.
https://honda-tech.com/zerothread?id=1769562</TD></TR></TABLE>
Double wrong.
https://honda-tech.com/zerothread?id=1523524
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by king-of-the-hill »</TD></TR><TR><TD CLASS="quote">you didnt even tape off the body parts around the headlights?????
Was just going to say that.
When I did mine, I took them off the car.
Wrong.
Double wrong.
</TD></TR></TABLE>Was just going to say that.
nope, i trust my hands very well, and even if i DID scratch the car, id just use MORE rubbing compound
</TD></TR></TABLE>nope, i trust my hands very well, and even if i DID scratch the car, id just use MORE rubbing compound
starting out with a 320grit doesnt seem right.....thats just too rough....
but as stated above.....if they are plastic, dont bother sanding, your fog will return within a matter of weeks.
I've tried and used several products to restore plastic headlights. Yes, they work great, however, they will get foggy again within a few days later. You can try to apply wax and/or protectant to keep them protected from UV rays, but you will need to do this on a weekly/monthly basis. The right way is to respray the headlights with plastic clearcoat, that I haven't yet found where or the product brand to buy it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J_CRX »</TD></TR><TR><TD CLASS="quote">The right way is to respray the headlights with plastic clearcoat, that I haven't yet found where or the product brand to buy it.</TD></TR></TABLE>
Ace Hardware should carry clearcoat for plastics, or you could always ask a local body shop about it.
But is the clearcoat resistant to chemical, weather, heat, etc..from behind outside of the car? I know of Duplicolor making clearcoat spray can for painting rims. Those has good protectants/resistants from what I've mentioned above, but can they sticks and be used on plastic? That I don't know!
Modified by J_CRX at 6:44 PM 6/30/2008
lol im jp with u, but thanks for the comments guys, hope this helps some ppl.
