ELD fuse box compatibility
Can anyone confirm what fuse boxes are compatible with 90 si hatch. I need to replace my ELD and from the searching i have done, people keep saying you need to find a fuse box from the exact year and trim level. Finding a 90 si hatch in the junk yard will not be easy so im looking to see if anyone can confirm what i can use. Thanks in advance
the only difference between the two are different fuse ratings on the cover of the box if you swap fuses they should be the same. I think the si came with dual horns and other models had one so the horn fuse is different. I was just looking at the two different ones the other day I had a spare of each and they both appear to be the same except for fuse size
From what I remember, there is an under dash type of fuse box labeled A and an under dash type of fuse box labeled B. They both look the same and I'm not sure about the difference between the two, maybe air conditioning? maybe mpfi?, but you should probably get the one that matches the letter of your old one. Look on the back for an A or B. BTW, if the eld plugs into the rear of the fuse box, maybe you just need a new Eld?...........good luck......
racecarpete
Audio / Security / Video
Mar 30, 2003 07:44 PM
