this is urgent. seriously
Old Jun 29, 2008 | 03:00 PM
minime-civic's Avatar
* B A N N E D *
Default this is urgent. seriously
so i am installing my hondata thermal intake manifold spacer, and it requires you to install longer intake manifold studs, well heres the problem, i have no clue how to get the intake manifold studs out of the head, can someone give me some tips?
Old Jun 29, 2008 | 03:02 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: this is urgent. seriously (minime-civic)
double nut them, use a stud remover, fwiw, i did not use longer studs, that i remember.
Old Jun 29, 2008 | 03:03 PM
* B A N N E D *
Default Re: this is urgent. seriously (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">double nut them, use a stud remover, fwiw, i did not use longer studs, that i remember.</TD></TR></TABLE>
ok cool, well i tried the double nut and stripped a nut out,
then i tried the vice grips, now its stripped and im [freak]ed .
Old Jun 29, 2008 | 03:22 PM
sicones's Avatar
I didn't use longer studs on my hondata gasket, but the nuts did come loose. I just torqued them down after a few driving cycles and it was fine.
If you really want to remove them, use vise grips or one of these:
Cestparti
Sep 3, 2010 06:45 AM
99_EM1
Feb 8, 2010 06:03 PM
ganjasnack
May 19, 2008 08:43 AM
redman223
13
Apr 1, 2006 08:44 PM
hatchattak
Aug 11, 2004 09:48 AM
