Spoon twin block caliper bleeding.................
I recently got a set of used Spoon twin blocks. As many know, there are two bleeder screws..............one on the inside and one on the outside per caliper.
Question is do I need to bleed the brakes through both bleeder screws per caliper or is one bleeder screw just fine???
for some odd reason, i found it easier to bleed from the inside bleeder first and then the outside one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coolhandluke »</TD></TR><TR><TD CLASS="quote">Are they convetional bleed screws? Or are they similar to speed bleeders?</TD></TR></TABLE>
conventional bleed screws...but smaller sized (8 or 7mm..can't remember)
hkrichard
Mar 18, 2008 07:51 AM
