Any help would be greatly appreciated :)
Hello I have recently run into an issue with my 96 accord ex transmission...
I have very slim knowledge of anything to do with a manual transmission... the 4th and 5th syncro have been slightly grinding but just recently after shifting out of 5th I could not shift into any of the cars gears...
The car is now sitting and with the clutch down its going into gears but having alot of trouble... what possibly could the issue be?
I would think the same but 1st 2nd and 3rd gear where perfectly fine not a single grind... would a bad 4th and 5th syncro cause all the others to also not let me into gear?
Update: I was just leaving work and shifted up to third gear out when out of now where the car make a big crash from the front end and dies out... the car still starts but now with the shifter in neutral it slowly dies and will stall out if you remove the foot off the clutch... oh what a day
d16efsedan
16
Nov 29, 2016 09:35 PM
KraKimus
Jun 29, 2010 07:31 AM
NateTheGreat
Jan 21, 2007 06:16 PM
