Oil Leak -NEED HELP!!!!
Old Jun 29, 2008 | 01:30 AM
da9kid11's Avatar
Default Oil Leak -NEED HELP!!!!
i have a 90 DA. i have noticed spots under my car where i park. checked under the car and i felt my oil pan. it was wet with oil and saw a drop fall.
What is the problem and how can i fix it???????
Old Jun 29, 2008 | 06:00 AM
ac_attak's Avatar
Default Re: Oil Leak -NEED HELP!!!! (da9kid11)
Find out exactly where it is leaking. If there is a hole in the pan then jb weld it.
Old Jun 29, 2008 | 06:33 AM
AWD Terror's Avatar
Default Re: Oil Leak -NEED HELP!!!! (ac_attak)
You need to clean all the oil off to find out where it's leaking from. The leak could be on top of the motor. Remember that silly thing called "gravity?"
Old Jun 29, 2008 | 06:36 AM
prb22786's Avatar
Check the oil pan gasket. Its a piece of rubber sandwiched between the oil pan and its mating surface above. If you see places where its bulged out or even ripped, it needs to be replaced. If the engine is warm and the oil thin you can see it leak faster from these bulge spots, but be careful. I found out about mine because it tore out right above the main exhaust pipe, and the oil dripping down was burning and almost caught my engine on fire.
The gasket itself is pretty easy to replace, just drain the oil, remove the pan, take off the old gasket and clean all surfaces, then reverse the process and put a new gasket in.
Uljima
Jun 3, 2015 06:17 AM
andylawcc
Oct 26, 2009 07:00 PM
immalooser
Sep 25, 2009 08:05 AM
uEDarkShadow
Jul 13, 2006 07:02 PM
Pinhead
Jun 9, 2002 01:53 PM
