anyone know how to install a shift light?
i just purchased a proform adjustable shift light. http://www.proformparts.com/mi...4b642
i was wondering if anyone knows how to install it. this is a noob question but it says to use an12volt ignition switch. where is that located? also a wire needs to be attached to the negative coil on a standard ignition.
thanks in advance
Modified by 2003em2 at 1:56 AM 6/29/2008
thanks in advance
Well I wired the hot wire on mine through the fuse pannel underneath the steering column. and as far as your ignition lead goes, there is a blue wire with a connector coming off of the harness next to your battery.
what about on a 91 civic si with B17 GSR mtor?? i tried tapping into the blue wire off the distributor. but it didnt work. i took this off my em2 nd trying to put it into my other car.
Sir Del Slow
Apr 28, 2003 09:49 PM
crashtest Sonny
Jun 23, 2002 11:22 PM
