? about my Eg's adjustable suspension
hey, i recently bought an eg, and it came with some adjustable coilovers...i wanted to drop it more, but i didn't know how to...It has 2 disc like things..im guessing you have to turn em around to drop it...but don't know how to...help please
...will have pics up soon of that part..to be more helpful
Most coilovers include a 'wrench'. This is used to grab the notch that is on the nut that holds up the spring of the coilover. Though this 'wrench' is not really necessary, it makes adjusting the coilover a lot easier. Almost anything that is sturdy enough to grab a hold of the notch and turn the nut would work to raise/lower the coilover.
yeah ive seen those wrenches...you think its possible to move it by hand??..cause i tried moving it, but the whole coil over moved..
That's why a coilover has two of those wrenches so you could turn one clockwise and the other counter clockwise.
I don't usually tighten my coilovers with those wrenches. I've done fine just hand tightening them.
you need 2 spanner wrenches to break the collars apart and to tighten them against eachother to lock the adjustment you made into place.
or use a flathead and a hammer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by count me out »</TD></TR><TR><TD CLASS="quote">...or use a flathead and a hammer.</TD></TR></TABLE>
be careful when doing this, it can mess up the collar to the point where a coilover wrench wouldnt be able to grab the collar
DoctorGSR
Suspension & Brakes
17
Mar 6, 2005 06:52 PM
