car wont move
Old Jun 28, 2008 | 09:33 PM
jdmdc4_77's Avatar
Default car wont move
i need help.
okay.
so we just finished swap a gsr on my integra.
anyways i am using a ls trans( better for boost)
we finished the project the yesterday
the car starts and all but if you put it in gear it doesnt move.
the car is on and you can put in in gear without pressing the clutch.
i know theres something wrong thats why before i do anything else
i wanna know what you guys think is wrong.?
thanks
Old Jun 30, 2008 | 06:13 AM
LSracing94's Avatar
Default Re: car wont move (jdmdc4_77)
did you hook up the shifting fork in the tranny properly
Old Jul 1, 2008 | 06:05 PM
nykid10466's Avatar
Default Re: car wont move (LSracing94)
same thing has happened to my eg, i was messing around with my new car which has in a b18c5 swap.... i need some help right away...... the car can go into gear without holding the clutch down....the clutch does have the same pressure as usual.....it has an exedy stage 1 clutch...idk if it's the clutch, i think it's the drive shaft, or the joint connection....but someone tell me what to check for to know whats the problem..... i just hope it's not something crazy serious.....helllppp
Modified by nykid10466 at 7:22 PM 7/1/2008
Old Jul 2, 2008 | 02:36 PM
gtec8285's Avatar
Default Re: car wont move (nykid10466)
check your axles if their in correctly if not then something else is wrong
Old Jul 3, 2008 | 12:05 PM
JDMPHILEP91's Avatar
Default Re: car wont move (gtec8285)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtec8285 &raquo;</TD></TR><TR><TD CLASS="quote">check your axles if their in correctly if not then something else is wrong</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSracing94 &raquo;</TD></TR><TR><TD CLASS="quote">did you hook up the shifting fork in the tranny properly</TD></TR></TABLE>
agree check your axles and your shift linkage.
Old Jul 3, 2008 | 12:11 PM
St. Jimmy's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmdc4_77 &raquo;</TD></TR><TR><TD CLASS="quote">i need help.
The LS transmission is horrible for boost, I'd love to hear your reasoning behind it being better tho.
As for your problem I would check to make sure all the shift linkage is ok, then check the clutch/fluid.
Old Jul 3, 2008 | 12:20 PM
Hanmin's Avatar
does your speedo go up when you put it in gear and rev it?
Old Jul 4, 2008 | 08:04 AM
LSracing94's Avatar
Default Re: car wont move (St. Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St. Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
As for your problem I would check to make sure all the shift linkage is ok, then check the clutch/fluid.</TD></TR></TABLE>
depends how much boost you are making jimmy, and what your goals are. The Ls trans makes for a moster boosted highway car, while the b16 might be a little quicker down the 1/4. But either way for a car making 500 HP i would probbaly go with the LS tranny
TackOut27
May 12, 2010 09:32 PM
nykid10466
Jul 2, 2008 08:50 PM
runthatboost
Jan 6, 2007 04:51 PM
kydragger
Feb 17, 2003 10:55 AM
[626]95-GSR
Feb 15, 2002 07:29 AM
