cracked sleeve
prolly dumb ??? but here i go...
if i cracked a sleeve ona b20. is it too late to resleeve the block or can i still resleeve it. cracks about an inch long....or shud i start lookin for another block. either way i go.im gonna resleeve. but can i still use the cracked block???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">you can resleeve a cracked block
edit: assuming the sleeve is cracked and not the block itself. </TD></TR></TABLE>
Like blinx9900 said, it depends where the crack it. Resleeving will replace the stock "sleeves" not the block.
What head are you using? If it's a vtec head, I would just resleeve a gsr block so you don't have to worry about using a B20vtec conversion kit. Also, gsr block comes stock with a block girdle. I PM'ed you
