tranny noise question
Old Jun 28, 2008 | 09:10 PM
strawberry's Avatar
Default tranny noise question
I've noticed since i swaped my b20 couple weeks back that when I'm cruising in 5th about 3500 ish or higher and i let off the gas there is a loud whining noise. I'm thinking its coming from my tranny. What are the chances that its my diff about to blow?
its a ys1 with about 50,000 on it from my old xsi swap
new act flywheel
new exedy stage 1
new throw out barring ect
I change the tranny fluid every 3-4 oil changes never any mettle shavings always honda trans fluid and 1/2 qt syncromesh.
shifts fine other than that
Thanks in advance
Justin
Old Jun 28, 2008 | 09:42 PM
Janos Lin's Avatar
Default Re: tranny noise question (strawberry)
Input shaft bearing is going bad I believe.
Janos
Old Jul 13, 2008 | 10:34 PM
DisOnesAPlaya's Avatar
Can anyone esle veriy thats its the input shaft going out.. can it be something esle. im having the same issue.. just got done with a swap.. tranny was fine before..
Modified by DisOnesAPlaya at 4:06 PM 7/14/2008
Old Jul 13, 2008 | 11:25 PM
redef90si's Avatar
Default Re: (DisOnesAPlaya)
i'd bet it's the input shaft bearing.Lucky you only hear it in 5th.I only heard mine i 1st(loud wine)I got my tranny rebuilt but as for your question i'd say thats what is wrong.
Old Jul 14, 2008 | 01:02 PM
Now i hear this whining noise even in netural as soon as i rev the motor up to 4k. can it be the clutch kit too.. maybe throw out bearing?? the tranny was fine, shift perfect in every gear. i just changed out my clutch and this is like my 30th clutch job ive done with cars ive own and my buddy cars.
Old Jul 19, 2008 | 10:45 AM
JaviITR
Jul 31, 2009 10:40 AM
Mike"IAMSLOW"Myers
Feb 24, 2008 02:40 PM
JT
Nov 1, 2007 08:52 PM
Aron Parsons
Mar 28, 2003 02:13 PM
