climate control light
Old Jun 28, 2008 | 08:37 PM
Dekorum's Avatar
Default climate control light
Why does my climate control light turn off sometimes when I turn the A/C off? Sometimes its even hard to get the light to come back on, its almost random. On top of that, only the lights on the left side work, not the whole right side of the climate control area. How do I fix this?
thanks!
Old Jun 28, 2008 | 09:00 PM
randomtask77's Avatar
Default Re: climate control light (Dekorum)
Every once in a while you have to knock on the dash to get the light to work.
Mine just stopped working altogether and from what I've read it's a little difficult to replace as you have to remove your stereo to get to the screws below the climate control to remove it.
Old Jun 28, 2008 | 09:30 PM
Dekorum's Avatar
Once you remove the radio, is there much more work to do? Will this be how to replace the bulb? How can a bulb stop working on one side though? I am thinking it is not a normal bulb..
Old Jun 29, 2008 | 05:04 AM
hondroid015183's Avatar
Default Re: (Dekorum)
Pull out the radio, including the metal brace and the bulbs are on the side of the HVAC controls, they are green or blue. You remove them with a dime or a flat screwdriver. That is for the 99-00 only.
Old Jun 29, 2008 | 10:06 AM
Dekorum's Avatar
Man, I keep forgetting this is not a model specific forum! This is for an EG hatch 92! So the 99-00 doesn't help..
triple beam
11
Jun 13, 2014 08:31 AM
lovelove
Aug 24, 2009 12:26 PM
Midori Green
Oct 27, 2008 07:24 PM
DOHCter VTEC
Apr 2, 2008 02:20 PM
Del Sol Man
Oct 26, 2002 07:47 AM
