Clutch pedal too high?
Old Jul 18, 2002 | 03:48 PM
ragejed's Avatar
Default Clutch pedal too high?
When I shoft or whatever, and let off the clutch, it doesnt engage untill im almost completely off the pedal, like a 1/2 inch, then there is the free play in the pedal. Its really annoying, cause Im not used to it, and it seems recent that its been like this. So when I go to press the clutch in, the rpms drop right after i press the clutch like an inch. any idea why? this is a new clutch, plate and flywheel, toda, act. Has almost 2k miles on all the parts
Old Jul 18, 2002 | 04:16 PM
ragejed's Avatar
Default Re: Clutch pedal too high? (ragejed)
anyone? i dont want to go to adjust the pedal just yet. seeing how its fairly new. I dont know what damage it might do to the throwout bearing, etc. just wondering if this is normal for a new clutch?
Old Jul 18, 2002 | 04:38 PM
Regular Series's Avatar
I dunno...the Teg's clutch engagement seemed a little high when I first got it. Seems OK now...check your clutch fluid level, you never know. Also, a Haynes manual can help you out with little items like clutch adjustments. They're nowhere near as good as a factory manual, but definitely worth twelve or thirteen bucks as a basic tuneup companion.
Old Jul 18, 2002 | 05:05 PM
ragejed's Avatar
Default Re: Clutch pedal too high? (risingson77)
i bought the hayes manual many months ago. and got my helms like a few weeks ago. The clutch master cylinder and tranny were replaced too. so it cant be that.
Old Jul 19, 2002 | 04:04 AM
RC211V's Avatar
i have the same problem with my pedal. it might just be a common thing with dc2's like the syncro problem they have
Old Jul 19, 2002 | 09:00 AM
ragejed's Avatar
Default Re: Clutch pedal too high? (JDMintegGSR)
hopefully
Old Jul 19, 2002 | 10:00 AM
96_GSR's Avatar
Most Honda clutches engage real high...Your clutch could also be nears it's end.
Old Jul 19, 2002 | 10:16 AM
fastludeh22's Avatar
Default Re: Clutch pedal too high? (96_GSR)
as long as it fully engages your fine, if you dont like it adjust it a little to be lower, whenever the master cylinder is changed the exact engagement point is going to change. it took me 4 adjustments to get it to where i liked it and it fully engeaged
edit: just make sure you dont make it too low then it wont fully dis-engage, but youll know
[Modified by 93ludevtec, 7:17 PM 7/19/2002]
Old Jul 20, 2002 | 03:45 AM
ragejed's Avatar
Default Re: Clutch pedal too high? (93ludevtec)
thanks, i just want it down a wee bit lower its soo far up im not sure if it fully engages. it doesnt slip tho
Mikej959
Nov 21, 2015 10:37 AM
JDM97dc2R
Jun 3, 2009 05:33 AM
mattmw88
Apr 23, 2008 09:57 AM
azian21485
Jul 7, 2004 04:06 AM
b20civic
Feb 1, 2003 07:38 PM
