priming new oil pump
Old Jun 28, 2008 | 06:10 PM
Death_to_Thieves's Avatar
Default priming new oil pump
How do I prime a new oil pump? where exactly do I fill it with oil? Do I remove the hex screw at the top or the bottom of the pump and just fill it with oil? White Lithium grease? I searched and couldn't find any info on this subject. Thanks alot in advance
-Jaysem
Old Jun 28, 2008 | 08:01 PM
inspyral's Avatar
Default Re: priming new oil pump (JAYSEM Society)
I've never heard of filling a pump with oil to prime it. I believe most people just pull the F/I fuse or disconnect the distributor and crank the engine over a few times to build oil pressure on a new setup or rebuild.
Old Jun 28, 2008 | 08:17 PM
stumpyf4's Avatar
Open the backplate and pack the oil pump gears with vaseline. Definitely worth doing as this will help create greater vacuum to pull oil from the pan. You may also want shim the pressure relief valve to increase pressure.
Old Jun 28, 2008 | 08:36 PM
downest's Avatar
Default Re: priming new oil pump (stumpyf4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">Open the backplate and pack the oil pump gears with vaseline. Definitely worth doing as this will help create greater vacuum to pull oil from the pan. You may also want shim the pressure relief valve to increase pressure. </TD></TR></TABLE>
I've heard of that, never tried it (no oil failures on countless engines) but it makes me a little nervous. There's no need to shim the pump, just remove the washer from the relief spring plug.
Old Jun 28, 2008 | 09:46 PM
mmuller's Avatar
Mad Scientist
Default Re: priming new oil pump (downest)
you can use assy lube to coat inside or take allen bolt and fill through there once in car
Old Jun 29, 2008 | 07:53 PM
stumpyf4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downest &raquo;</TD></TR><TR><TD CLASS="quote">
I've heard of that, never tried it (no oil failures on countless engines) but it makes me a little nervous. There's no need to shim the pump, just remove the washer from the relief spring plug.</TD></TR></TABLE>
I like to leave the washer on the plug, I think of it as a crush washer used for sealing. Instead put a washer (shim) under the bolt to compress the spring a bit more. Different ways to skin a cat.
Old Jun 29, 2008 | 08:57 PM
downest's Avatar
Yeah I see what you're saying... but ITR pumps don't use that washer nor a shim, so I assume it's fine not to. Also there's no pressure on that part of the pump, so it doesn't need a tight seal.
oscar112709
Apr 18, 2019 12:52 AM
b20eghatch
11
Jul 12, 2010 11:24 AM
sk8rmike
Oct 8, 2003 08:41 PM
iwouldHITit
Jul 17, 2003 04:11 AM
Mefain
May 16, 2003 09:02 AM
