15x8 wheels will 205/50/r15 tires fit???
Old Jun 28, 2008 | 10:25 AM
taimysho0's Avatar
Default 15x8 wheels will 205/50/r15 tires fit???
Hey guys, i have a 2000 honda civic si and just bought some rims that are 15x8 with a +25 offset. i didnt wunna buy new tires cuz i already have new ones on my civic. so im planning to swap the ones i have now which are 205/50/r15 onto the 15x8 wheels. will that fit???? any safety issues? rubbing? my car is loweres 2.5 in the front and 2.25 in the rear. thanks!
Old Jun 28, 2008 | 10:52 AM
DDEVIANT1's Avatar
Default Re: 15x8 wheels will 205/50/r15 tires fit??? (taimysho0)
The tires should stretch to fit the rims...I would look at the tires manufacterurs website to get the exact specs.... But with taht offset and being dropped it might rub, or hit the fenders over bumps or when turning.
Old Jul 1, 2008 | 08:35 AM
Blwnb18's Avatar
They will fit, but they are going to have that sloped look on the sidewall. It's going to have that ramped look. I would recommend going more with a 235 on a 8 inch wide wheel. I have 215 on my 7 inch wheels and they are almost perfect. I mean you could even go with a tire as wide as 245 probably on those. But those sizes will probably rub.
Old Jul 1, 2008 | 08:45 AM
nsxtasy's Avatar
H-T Order of Merit
No, it's a bad idea.
Most 205/50-15 tires are approved by their manufacturer for mounting on wheels 5.5-7.5 inches wide. And you really don't want to mount tires onto wheels wider than the approved range (even though you may be able to stretch them onto a wider rim). They can build up excessive stress and heat in the sidewall, and this can lead to failure/blowout/etc. It's unsafe and just a bad idea all around.
225/45-15 tires are usually approved for mounting on 15x8 rims. However, they rub on most cars. That's why they're used primarily for racetrack events, and not for street use.
Old Jul 1, 2008 | 09:17 AM
Blwnb18's Avatar
Exactly. I have seen it done, but it looks like doo-doo.
hondapeeler
Dec 2, 2010 08:59 AM
JDM SLICK
Apr 13, 2006 02:38 AM
urnotfast
Sep 18, 2005 06:47 AM
urbanhoney
Feb 4, 2004 07:45 PM
lazyvietboi
Apr 2, 2003 05:54 PM
