will 215/45/16 rub?
The wheel choice is a critical detail here. I run Yokohama 225 45-16 on wheels with a +43 offset. The rears rubbed the rubber trim. Once the trim was removed, no rubbing occured. That is the maximum tire width that will fit the rear of a DC2 or DC4.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmongyaj87 »</TD></TR><TR><TD CLASS="quote">did you have to roll you rear fender? does it rub when you turn?</TD></TR></TABLE>
I thought that I was going to have to roll the fender. But after removing the rubber trim, there was no more rubbing even when turning. Like I said, those tires are wide. I have maybe 1/4" between the tire and fender and 1/4" between the tire and spring. (The clearances are for a compressed suspension.)
