code ELD....where is it, how do I fix?
Old Jun 28, 2008 | 08:07 AM
cdmef's Avatar
Default no more code ELD....no gas no start
So I go to start my new beater and no start, code 20 Electric load sensor. I know nothing about this sensor, and there is no wire running to bin 19, where it should be. the car is a 91 sedan with a jdm sohc no vtec. Please help with where the ELD is, how to fix etc. I just want to drive this damn thing It was running great yesterday.
Modified by cdmef at 1:37 PM 6/29/2008
Old Jun 28, 2008 | 08:11 AM
JOE BD-0's Avatar
Default Re: code ELD....where is it, how do I fix? (cdmef)
My electric load detector code only ever came on when the rear wire loom was unplugged. This was the loom that goes to the rear brake lights, etc.... good luck
Old Jun 28, 2008 | 08:26 AM
cdmef's Avatar
Default Re: code ELD....where is it, how do I fix? (JOE BD-0)
Yeah there was some funk going on back there, but the weird thing is that I got everything to work, and the car was running really well and then out of the blue....
I'll go over the whole rear and underdash now and we'll see what we can see.
Old Jun 28, 2008 | 08:46 AM
cdmef's Avatar
well, everything electronic I can find is working fine. Joe, do you know where the ELD is so I can check it out? I read its in the ecu, so I tried another pm6 and still the same. I need to know where it is so I can try running a new wire....???
Old Jun 28, 2008 | 12:40 PM
cdmef's Avatar
bumpity so I can drive this thing?
Old Jun 28, 2008 | 01:50 PM
Crx Jimmy's Avatar
An eld code should not stop it from starting. The eld itself is integral to the underhood fuse box. I think you need to get another fuse box itself. check it out you might have some melted stuff in there stopping it from starting.
Old Jun 28, 2008 | 02:13 PM
cdmef's Avatar
Default Re: code ELD....where is it, how do I fix? (Crx Jimmy)
Ok Jimmy, I have another fuse box to try. I looked in there earlier and everything looked ok, but I'll try it.... I was thinking the same thing about not starting. It started for a while, acting like it was only on 3 cylinders and now no more starting. The car was messed with a bit, and an engine swap so who really knows what may be causing the no start.
Old Jun 28, 2008 | 02:34 PM
cdmef's Avatar
rrright, no dice on the fuse box, I tried a known good one and still code 20 and no start (the starter goes like mad, and at most it'll sputter a bit)
anyone? please? This car is draining my will t owork on my good one
Old Jun 28, 2008 | 04:39 PM
traxxasx's Avatar
eld usually means you missed a ground. make sure youve got the thermostat ground, the engine (valve cover) ground and the transmission ground.
Old Jun 28, 2008 | 06:06 PM
cdmef's Avatar
Default Re: (traxxasx)
May be ground but its not a fresh swap, the previous owner has been driving it with the engine swap for a year with no issues that I know of, and it was running for the couple times I have driven it.... Its weird that it won't start as well as have a code that shouldn't relate to running.
Old Jun 29, 2008 | 03:30 AM
cdmef's Avatar
Default Re: (cdmef)
goin to check spark and fuel today, I was wondering about that yesterday, but didn't have time.
Old Jun 29, 2008 | 05:28 AM
cdmef's Avatar
Default Re: (cdmef)
S oit seems th eno start is fuel, nothing past injectors but but there is fuel past the rail, although it seems weak.... I'm trying the injectors from my b16(running) and we'll see if its the fuel pump itself, which I think it may be....I'll keep ya posted
Old Jun 29, 2008 | 06:31 AM
cdmef's Avatar
Default Re: (cdmef)
well, the injectors were good, theres lots of pressure from the system, so its going to be wiring afterall. I think.
Old Jun 29, 2008 | 07:26 AM
Mr.Death's Avatar
Default Re: (cdmef)
You need a fuse box from an American car as the Canadian cars do not have an ELD built into them. I have the same code on my car for some time now but the only problems I have are after warm up(lumpy idle), other than that it drives perfectly. I bet your ECU is from an American car and is looking for the ELD which is not present. Either get a Canadian ECU or an American fuse box.
Old Jun 29, 2008 | 08:28 AM
cdmef's Avatar
Default Re: (Mr.Death)
Good to know mr death. hah. love it. so I took care of the code, still not starting
Modified by cdmef at 2:23 PM 6/29/2008
Old Jun 29, 2008 | 12:40 PM
cdmef's Avatar
Default Re: (cdmef)
alright. replaced the main relay, it runs. now it has code 9 (cps) and has huge throttle hesitation so I guess I have to try to find a dizzy here in the boonies. yay.
Modified by cdmef at 2:20 PM 6/29/2008
ESPTUNING
Mar 28, 2005 07:24 AM
undefinedcrx
Mar 12, 2004 01:11 AM
RedStarGsr
Feb 18, 2004 09:39 PM
slowpokesi
Apr 7, 2003 12:19 AM
White Lightnin
Jun 28, 2002 09:15 AM
