Fuel return vacuum line?
I know that it ends up there... but i was reading a diagram that shows the fuel pressure regulator vacuumed into the FPR control solenoid valve and than into the manifold.. so I guess the question is Do I need the control valve or can i just run it into the manifold and have it be fine? Also when I plug it into the manifold my car idles @ 500 and wants to bog out n die.. do you think its a bad FPR?
civiclxb16a
13
Mar 24, 2005 02:57 PM
