HELP!!! Car won't stop backfiring!!!!
I have a 96 integra with a 96 JDM GSR swap
OK, Here's the deal....one day I was rippin it up on some country roads and all of the sudden when I floored it it would bog down (tremendously) and backfire. But it only does it when I floor it...I can tack it out if I am easy on the pedal.
Right after all of this, I replaced the head gasket, manny gasket and checked the timing....timing is good.
Awhile back I started a thread on this and some guys said that it might be my temp sensor and or sylinoid....replaced both.
Just took it out for a test drive and ta da!!! STILL BACKFIRING! Any ideas????
Thanks
Modified by JaayDeeM at 1:49 AM 6/29/2008
OK, Here's the deal....one day I was rippin it up on some country roads and all of the sudden when I floored it it would bog down (tremendously) and backfire. But it only does it when I floor it...I can tack it out if I am easy on the pedal. Right after all of this, I replaced the head gasket, manny gasket and checked the timing....timing is good.
Thanks
