Why do I need an obd1 dizzy?
Old Jun 27, 2008 | 10:11 AM
Ocnaj's Avatar
Default Why do I need an obd1 dizzy?
I really didn't know how to search for this and even if I did how successful it would be I don't know.
Here's the deal; I have an A6 w/ a Y8 head in a CRX Si. I have the jumper harness and a p28. I talked to a few honda guys around where I live and they said I don't need an obd1 distributor. I was wondering why I would need one if it did require to have one. Can anyone shed some light? Thanks - Dave
Old Jun 27, 2008 | 10:26 AM
crx_si-r's Avatar
Default Re: Why do I need an obd1 dizzy? (Ocnaj)
well who ever your honda guys are i think you should slap em upside the head. yes you need an obd1 distributor. if you dont run one your car will not run. you can use and obd2 dizzy as well you just need to re-pin it (or pm me i can make adapter harnesses for the dizzy if your uneasy about re-pinning). there is an added sensor i believe in the obd1+ dizzy that the ecu looks for without it the car wont run.
i know this because i tried to run my 89 z6 HB wit the stock si dizzy and it didnt run till i put in the obd1 dizzy.
Old Jun 27, 2008 | 03:20 PM
dr_latino999's Avatar
Default Re: Why do I need an obd1 dizzy? (crx_si-r)
OBD-0 Distributor outputs signal at 16 Pulses / Revolution.
OBD-1 Distributor outputs signal at 24 Pulses / Revolution.
The corresponding ECU's are only looking for that signal, any more or any less they can't use the data.
Old Jun 27, 2008 | 04:56 PM
Ocnaj's Avatar
Thanks both of you for the info. I probably will give em a couple smacks... Si R, do you sell the adapter plugs? Does it need to be a V-tec dizzy?
Modified by Ocnaj at 6:38 PM 6/27/2008
Old Jun 27, 2008 | 10:48 PM
gursh d's Avatar
Default Re: (Ocnaj)
check out http://www.rywire.com
They sell dizzy adapters, OBD conversions, and other wiring related things. You can find stuff on ebay as well.
Old Jun 27, 2008 | 10:56 PM
Janos Lin's Avatar
Default Re: (gursh d)
Z6 distributor has a different bolt pattern than the A6 and Y8. So you need to get the correct one. OBD-1 and 2 distributors have the same outputs, OBD-0 does not. So you can either use the OBD-2, or the OBD-1 with the correct bolt pattern. Dont ask me which one as I'm too tired to dig up the specific model. Go bother a well written mini-me guide.
Janos
Old Jun 27, 2008 | 11:28 PM
monotech's Avatar
OBD-0 to Obd-1 dizzy adapter
Or get your harness converted to this
Parts needed for conversion:
*Obd-0 to Obd-1 ecu jumper harness
*Obd-0 harness converted to Obd-1
*Obd-1 ecu & Distributer
*4 wire o2 sensor
* I make all these conversions along with adapters and sub harnesses *
Modified by monotech at 8:12 AM 6/28/2008
Old Jun 28, 2008 | 06:23 AM
Default Re: Why do I need an obd1 dizzy? (monotech)
You don't need to have an adapter unless for some reason you plan on reverting back to OBD-0 in the far distant post-apocalypse future.
Old Jun 28, 2008 | 06:50 AM
crx_si-r's Avatar
Default Re: (Ocnaj)
yes i make and sell the dizzy adapter plugs. pm or email me crx_si-r@sbcglobal.net
oh and rywire no longer sells the obd0-obd1 dizzy adapter harness seperately. just thought youd like to know.
Old Jun 28, 2008 | 01:32 PM
Spikey640's Avatar
Default Re: (Janos Lin)
yeah you def need an OBD1 distributor
whoever u talked to are way off
and by A6, im sure u mean D16
Old Jun 29, 2008 | 12:01 AM
mario_pic's Avatar
use a obd1 dx dizzy im runing a y8 with a 92 dx dizzy fites and lines up like the stock y8 dizzy
Old Jun 29, 2008 | 09:59 AM
Malgerus's Avatar
Default Re: Why do I need an obd1 dizzy? (mario_pic)
You can also use a Y8 distributor. OBD-II distribs work with OBD-I
Old Jun 29, 2008 | 06:45 PM
Ocnaj's Avatar
Default Re: Why do I need an obd1 dizzy? (Malgerus)
So a Y7 dizzy would work also? Thanks everyone for the help.
Old Jun 29, 2008 | 06:59 PM
crx_si-r's Avatar
a D16Y8 dizzy will bolt up
Old Jun 30, 2008 | 06:11 AM
Ocnaj's Avatar
What about a Y7 dizzy?
Blueallie
Mar 16, 2009 03:49 PM
LSXFEIND
Mar 12, 2009 06:09 AM
lilsicsoul
Jan 23, 2009 03:52 PM
richboi
11
Apr 17, 2006 04:36 PM
vegaskurt
May 14, 2005 10:17 PM
