Setting the ignition timing
Old Jun 27, 2008 | 08:36 AM
killacam661's Avatar
Default Setting the ignition timing
i have a 95 gsr integra and i did the timing last night on it and aligned all the marks( on the cams and on the crank), and i had the dizzy set right in the middle(not advanced or retarted), but when i put the timing gun on it the mark was soo far above the middle timing mark on the crank. i have done the timing several times and it never gets close to being at 16 degrees BTDC. no matter how advanced i put the dizzy. ive done the timing on a few b16s and they ran strong with the timing marks all aligned, but the gsr has been giving me troubles and i cant figure out how to get it running good. ANY SUGGESTIONS?
Old Jun 28, 2008 | 08:00 AM
Default Re: Setting the ignition timing (killacam661)
ttt
Old Jun 28, 2008 | 08:08 AM
jwrape's Avatar
Did you put a paper clipin the two prong plug above the ECU?
Old Jun 28, 2008 | 08:41 AM
Default Re: Setting the ignition timing (jwrape)
ya and its blinking o2 sensor... but thats all
Old Jun 28, 2008 | 08:49 AM
jwrape's Avatar
Hmmm, should work as long as that plug is crosses.
Don't know
Old Jun 28, 2008 | 09:13 AM
all-mtr-teg's Avatar
My timing marks on the timing belt cover never matched up with what my ecu was saying. According to my ecu I was at 14 BTDC but the gun said 16 BTDC. The timing mark groove on the timing belt cover is usually a bit off.
dem0nk1d
Jun 27, 2012 12:39 PM
dr_latino999
Dec 2, 2004 09:55 PM
dsCRXsi
May 2, 2004 04:32 AM
