recharging AC
Old Jun 27, 2008 | 03:11 AM
ATrin's Avatar
Default recharging AC
I know the process on recharging refrigerant into a unit. My only question is, How much refrigerant do you put in?
If completely vaccumed. I know they sell 8oz and 12oz cans of R134a.
I'm planning on doing this weekend. Thanks.
Oh 94 LS Sedan.
Old Jun 27, 2008 | 06:28 AM
all-mtr-teg's Avatar
Default Re: recharging AC (ATrin)
Look in your engine bay, there should be a sticker that says how many ounces of freon your system holds If not, make sure you use a manifold with a gauge to install the freon, and don't go above the recommended PSI on the low side. I usually charge up to about 35-40 PSI, it depends on how hot the environment is at the time.
Old Jun 27, 2008 | 01:26 PM
ATrin's Avatar
Default Re: recharging AC (all-mtr-teg)
cool thanks. I have a set of gauges. I'm in Dallas tx and its been pretty hot lately.
Old Jun 27, 2008 | 02:06 PM
ATrin's Avatar
does anyone know which valve is the high side and the low side? there's one right behind the ac fan motor and another kinda behind the driver side headlight. i'm guessing the one behind the fan is the low and the other is the high?'
TIA
Old Jun 28, 2008 | 12:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATrin &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know which valve is the high side and the low side? there's one right behind the ac fan motor and another kinda behind the driver side headlight. i'm guessing the one behind the fan is the low and the other is the high?'
TIA</TD></TR></TABLE>
Yup, remember, your a/c recharge hose should only fit on your low side fitting.
9.3.S.I.L.U.D.E.
Jul 17, 2010 05:58 PM
94LS_allmota
Jul 24, 2009 06:06 PM
dayaftertomorrow33
May 4, 2009 09:24 PM
Totalpkg
Jun 10, 2005 10:51 AM
