brake line
I was wondering when i did a rear disk conversion do i have to use the integra rear brake line?
could i use the Si brake line on my integra rear conversion parts?
As of why im asking could i use the si brake line because i think the GSR brake line is leaking where the tread is connect to the other line.
How i know is that they don't connect good so i have to force it in a way.
seeing that i losing brake fluid in the mc really slowly and still have good brake power.
I only bleed the rear i haven't bleed the front just to let yall know.
All rear disc hoses are the same.
Be sure it is the hose is the only part that needs replacing... If youre not getting a good seal, its possible the threaded fitting on the hardline is damaged as well... Worse case scenario, you will have to replace it.
You have to bleed in the correct sequence, not just front or rear at one time and walk away - you have to do all corners at once.
The order is:
1. Passenger Rear
2. Driver Front
3. Driver Rear
4, Passenger Front
The order is:
1. Passenger Rear
2. Driver Front
3. Driver Rear
4, Passenger Front
PINKS
Oct 18, 2007 06:04 AM
EF_ST@TUS
Apr 12, 2006 01:00 PM
