OBD1 Sensors and Misc. P06 ECU.
I have a ton of OBD1 sensors laying around that need to go.
Intake Air Temperature - IAT
Vehicle Speed Sensor - VSS
Engine Coolant Temperature - ECT
Coolant Temperature/Fan Switch
Throttle Position Sensor - TPS
Map Sensors
Oil Pressure Sensor
Baro Sensor
H22 EGR Sensor assembly
H22 EGR valve
H22 Power Steering Pump - JDM h22
H22 A/C Bracket - JDM H22
h22 Power Steering Bracket - JDM H22
JDM OE Exhaust manifold and bottom pipe with good flex joint
Alot of other misc. items from D, B, H series OBD1 engines and transmissions.
Also have some D Series transmission internals that are in good shape.
P06 ECU VIRGIN!
http://cgi.ebay.com/ebaymotors...l1318
Also have all OE Sensor connectors (for wiring harness)
OE JDM H22 shifter rod and boot
Misc. nuts and bolts off of Honda's.
If your looking for something strange (NO body parts, all engine and electrical)
Give me a shout there is a real good chance I have it.
BTW, you will have a better chance of getting ahold of me VIA email, I'm not on here much.
JSarv03@gmail.com
Map Sensors
Oil Pressure Sensor
Baro Sensor
H22 EGR valve
P06 ECU VIRGIN!
JSarv03@gmail.com
