how did you get rid of that vacuum line?
see where his breather is on his valve cover? theres a hard line from there to the intake piping that is attached to something else. how do you get rid of it, cuz i need to put a breather on there cuz the hard line is hitting my charge pipe
if we are talking about the same line (its the line that use to vent to the intake arm and another line is welded to it), since you got turbo you dont need the vent line going back to the arm., you can rip it out and replace the bottom one with a new hose.
yeah, the bottom one already has stuff tapped on each side of it so i wanna leave that alone, but the vacuum line im talking about sits right on top of that one. howd you guys yank that out?
The other line is for the coolant that runs from your block to the thottle body. You could just replace that hard line with another hose and the stock piece will come out. Just follow the hose to where they are suppose to go.
coolant? ididnt have any coolant come out of mine , just rip the thing out .
that whole **** goes to the stock airbox, and to the pcv valve.
nice!!!!!
the line below the one youre talking about is the coolant line.
NitroSign
Welding / Fabrication
May 20, 2005 05:20 PM
