question about si trans
Old Jun 26, 2008 | 05:16 PM
crazy sohc vtec guy's Avatar
Default question about si trans
i searched and couldnt really find anything helpful. i am going to look at a transmission on sunday to buy it. i was wondering how you can tell the difference in a si trans and a dx trans and if theres any ways to see if it grinds. thanks
Old Jun 26, 2008 | 05:31 PM
D16SiHatch's Avatar
Default Re: question about si trans (crazy sohc vtec guy)
Assuming the sticker is still on it, it should say L3 which designates it being an Si transmission. my Si trans i just pulled the other day for example says "L3-2027106". and as far as i know there isn't anyway you can tell if its going to grind without installing it and going for a drive
ninja edit: dont pay attention to me. the information i got from a diff site on how to differentiate an Si trans from others was INCORRECT. these guys below know what they're talkin about
Modified by D16SiHatch at 11:26 PM 6/26/2008
Old Jun 26, 2008 | 05:59 PM
Janos Lin's Avatar
Default Re: question about si trans (D16SiHatch)
Si, DX, HF and ZC (I think) all say L3. There used to be a picture showing how far the differential would rotate when the input shaft was turned while in a certain gear, but I can't find it anymore. Some pack rat around here (mista?) might have it.
Janos
Old Jun 26, 2008 | 06:02 PM
EFstyle's Avatar
Default Re: question about si trans (Janos Lin)
*EDIT*... what he said lol
Old Jun 26, 2008 | 06:21 PM
AK_CRX's Avatar
https://honda-tech.com/zerothread?id=1551508 in the CRX faq sticky.
look above the oil fill, there is a stamp that will say PL3/####
PL3/A### = small bearing case - DX/HF/STD
PL3/B000 = large bearing - SI/ZC
PL3/3000/6000/9000 = large bearing - SI/ZC
as for clutches, as long as you have a 90-91 flywheel it will use a 90-91 SI clutch. unless the trans is an '88(21 spline input shaft)
Old Jun 26, 2008 | 06:49 PM
josh352727's Avatar
Default Re: question about si trans (AK_CRX)
I would run vin for it at carfax, should tell you the type of car/year it came from for free.
Old Jun 26, 2008 | 07:16 PM
dispocrx's Avatar
Here is the picture you want...as for it grinding i dunno how ya help ya!
Old Jun 27, 2008 | 05:27 PM
thanks for the quick responses everyone
Old Jul 4, 2008 | 01:42 PM
OK GUYS ONE MORE QUESTION. THE STAMP SAYS PL3 9000 BUT THE STICKER SAYS SL-???????. IS THIS A SI TRANS
Old Jul 4, 2008 | 03:33 PM
dr_latino999's Avatar
Default Re: question about si trans (josh352727)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by josh352727 &raquo;</TD></TR><TR><TD CLASS="quote">I would run vin for it at carfax, should tell you the type of car/year it came from for free.</TD></TR></TABLE> Our parts never had the VIN number attached, good idea though.
Old Jul 10, 2008 | 01:23 PM
MOE@Hyper16Valve's Avatar
Default Re: question about si trans (dr_latino999)
Good 411...
Old Jul 10, 2008 | 02:29 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (crazy sohc vtec guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazy sohc vtec guy &raquo;</TD></TR><TR><TD CLASS="quote">OK GUYS ONE MORE QUESTION. THE STAMP SAYS PL3 9000 BUT THE STICKER SAYS SL-???????. IS THIS A SI TRANS</TD></TR></TABLE>
Doesn't matter, only way to tell is using the method described above. There's also no way to tell if there are going to be grinds without cracking it open.
Try and see if you hear any grinding noises coming from the input shaft as well, that would be an indicator of bearing wear.
I would just rebuild it anyways, but that's me
d16man
Nov 28, 2008 12:13 AM
C_R_X_V_T_E_C
10
Feb 13, 2007 04:04 PM
bigwill_2004
Jun 14, 2006 01:58 PM
Ronin Panda
Apr 25, 2003 08:31 PM
4gvtec
13
Sep 10, 2002 08:30 AM
