any benefits from a gsr tranny?
Old Jun 26, 2008 | 03:15 PM
turboteg90's Avatar
pm for noodz
Default any benefits from a gsr tranny?
i have a b16a3 and 3rd gear is goin bad,i seen a lot of peple run b16 with gsr transmisions,are there any benefits in doin this?and is it just a bolt on?
Old Jun 26, 2008 | 04:37 PM
GReatEDDY's Avatar
Default Re: any benefits from a gsr tranny? (turboteg90)
I would rebuild the Y21 you have. Basic rebuild would be cheaper in the long run. Even if you find a good tranny theres no guarantee the replacement isnt going to have a grind or high rpm pop out. Save, rebuild. The only thing you may want to consider is a diff. If you have that then change the final drive down. Adding either of these now is just plain cheaper to add now. Then your all wrapped up and ready for another 100K.
IMO
Old Jun 26, 2008 | 05:01 PM
turboteg90's Avatar
pm for noodz
Default Re: any benefits from a gsr tranny? (GReatEDDY)
100k?is that how long they last?,my motor has like 60k and the tranny is goin bad already? .its weird it grinds sometimes,for example if i power shift everything goes perfect no grinds or high rpm gear pop out.but if i drive normal it grinds also if i shift slow it goes in perfect,sometimes i think that maybe is my cluth that need to be adjusted or i suck at shifting to third gear.
Old Jun 26, 2008 | 05:40 PM
GReatEDDY's Avatar
Bleed the slave, and keep bleeding it out until you see new fluid coming out. then drive its a easy adjustment that is often over looked. No matter what you decide to do you will more then likely be replacing the clutch anyways.
lilshady6796
29
Oct 13, 2008 03:33 PM
93gsrcoupe
Mar 16, 2005 07:00 PM
dantheman203
Oct 29, 2004 12:41 PM
X2BOARD
12
Dec 11, 2003 09:33 AM
VTC_CiViC
Oct 8, 2001 02:50 PM
