Questions About EF8 Gauge Cluster
Old Jun 26, 2008 | 01:49 PM
c.dub's Avatar
Default Questions About EF8 / EF9 Gauge Cluster
I understand that the EF8 gauge cluster requires a electronic VSS instead of the cable one that comes in the ED9? Where would I get the correct VSS for this cluster? Is there any extras I would need to do the install that I would not get with a cluster I bought on eBay for example? Do any of the features on the cluster not work in an ED9?
I have read some articles on the install, but a lot of the articles I found were down.
Thanks
Old Jun 28, 2008 | 11:48 PM
GSR CRX's Avatar
Default Re: Questions About EF8 / EF9 Gauge Cluster (c.dub)
an electronic vss is not required. you can still use the cable vss by keeping the just the odometer part of the cluster. once the odometer is out you will notice that there are two holes where you can thread two screws. that is where you can attach two wires and send them to the correct locations on the electric vss and the harness to the ecu. ill will try to post the link where it shows you how to do the conversion.
Old Jul 3, 2008 | 07:11 AM
reynardmauricio's Avatar
corey, if u need an electronic vss, lemme know as i have one kicking around
siregcivic
Oct 10, 2011 10:43 AM
bigBOI_92DA9
Aug 6, 2005 09:03 AM
darkspector
Apr 10, 2005 12:29 AM
