Car won't start
Old Jun 26, 2008 | 01:48 PM
TheOdd001's Avatar
Default Car won't start
Went to start my car and all the dash lights came on... Went to start, heard a click, all the dash lights go off, checked the battery voltage 12.3V. When I go to start, the battery voltage drops to near zero! some sort of ground? Where could it be? I checked the starter cut relay looked fine. Even jumped across the relay with same results just a click, dash lights out and no starter turn.
Old Jun 26, 2008 | 02:26 PM
vtecb18c's Avatar
Default Re: Car won't start (TheOdd001)
sounds like a ground but you may need a new starter
Old Jun 26, 2008 | 07:49 PM
dtapia's Avatar
Default Re: Car won't start (vtecb18c)
yea the load is going some where else besides the starter. check the battery cable to the starter and battery and the ground wire. or may also have a electrical portion of the ignition switch causing problems also.
what year and make is the car ? all stock or got alarm and other mod's ?
Old Jun 26, 2008 | 08:19 PM
TheOdd001's Avatar
Default Re: Car won't start (dtapia)
It was the starter. Two wires and two bolts later VROOMM!
Old Jun 26, 2008 | 08:40 PM
dtapia's Avatar
glad it worked out
Old Jun 26, 2008 | 08:41 PM
vtecb18c's Avatar
glad we could help
DriveSlowHomie
Jan 26, 2010 10:31 PM
TheOdd001
Jun 26, 2008 08:19 PM
TheOdd001
Jun 26, 2008 08:17 PM
crxaddikt
12
Dec 4, 2007 12:19 PM
R-81DC2
May 22, 2006 01:33 PM
