Car won't start
Old Jun 26, 2008 | 01:48 PM
TheOdd001's Avatar
Default Car won't start
Went to start my car and all the dash lights came on... Went to start, heard a click, all the dash lights go off, checked the battery voltage 12.3V. When I go to start, the battery voltage drops to near zero! some sort of ground? Where could it be? I checked the starter cut relay looked fine. Even jumped across the relay with same results just a click, dash lights out and no starter turn.
Old Jun 26, 2008 | 05:19 PM
b20vtech's Avatar
Default Re: Car won't start (TheOdd001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheOdd001 &raquo;</TD></TR><TR><TD CLASS="quote">Went to start my car and all the dash lights came on... Went to start, heard a click, all the dash lights go off, checked the battery voltage 12.3V. When I go to start, the battery voltage drops to near zero! some sort of ground? Where could it be? I checked the starter cut relay looked fine. Even jumped across the relay with same results just a click, dash lights out and no starter turn.</TD></TR></TABLE>
must be a non-vtec engine!
Old Jun 26, 2008 | 06:52 PM
cyb3rjak's Avatar
Default Re: Car won't start (b20vtech)
is your starter cable plugged in? mine came loose. do you have an alarm?
Old Jun 26, 2008 | 06:55 PM
( o )( o )'s Avatar
sounds like a dead battery. i have had batteries show 12v but would not crank. also check for corrosion at the terminals, clean them if necessary and tighten them up. if that doesn't help then try a jump start with another car. then drive to the auto parts store to get a new battery.
Old Jun 26, 2008 | 08:17 PM
TheOdd001's Avatar
Default Re: Car won't start (( o )( o ))
Was the starter! Thanx for the help!
TheOdd001
Jun 26, 2008 08:41 PM
TheOdd001
Jun 26, 2008 08:19 PM
p_en03
Jan 24, 2008 05:10 PM
