Caliper Brackets?
Old Jun 26, 2008 | 12:18 PM
EJ8 GSR-T's Avatar
Default Caliper Brackets?
I am trying to throw a pair of these on my civic, i have had this set sitting around for awhile and was going to take the brackets off to get milled to fit the civic. However these kinda look like they already have been?? The are 23t brackets...Any input, as i dont know what they look like stock...
Old Jun 26, 2008 | 03:36 PM
JOHN WAYNE's Avatar
Default Re: Caliper Brackets? (EJ8 GSR-T)
23T brackets will fit fine as long as you make sure that you get 23mm thick rotors.
Old Jun 26, 2008 | 10:08 PM
Bbasso's Avatar
Bahhh take this to the hybrid forum.
These type of this came on our caRs...
Old Jun 26, 2008 | 10:50 PM
SuckMyDOHC's Avatar
Default Re: Caliper Brackets? (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Bahhh take this to the hybrid forum.
Old Jun 27, 2008 | 05:43 AM
jomama's Avatar
they are milled for sure already (obviously). what i would do is throw on a pair of prelude vtec rotors on there and see if they fit. those are the best rotors if you still have the 4x100 suspension. they give you the 11" rotor size with the correct center bore and the correct thickness, etc. PM me if you need any help as i did a bunch of research for this in the past even though i never went through with it with my GSRs GL
Old Jun 27, 2008 | 09:22 AM
CW-ITR's Avatar
Default Re: (jomama)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jomama &raquo;</TD></TR><TR><TD CLASS="quote">they are milled for sure already (obviously). what i would do is throw on a pair of prelude vtec rotors on there and see if they fit. those are the best rotors if you still have the 4x100 suspension. they give you the 11" rotor size with the correct center bore and the correct thickness, etc. PM me if you need any help as i did a bunch of research for this in the past even though i never went through with it with my GSRs GL</TD></TR></TABLE>
Old Jun 28, 2008 | 01:19 AM
EJ8 GSR-T's Avatar
Default Re: (CW-ITR)
Thanks bro, Got the rotors..just waiting on the pads now! I ended up going with the AEM pads, the car is street driven...nothing fancy. Anyone running the AEM pads w/ brembo rotors??
Old Aug 1, 2008 | 02:55 PM
BrakeExpert's Avatar
Default Re: (EJ8 GSR-T)
Those brackets are not milled or grinded. they are stock.
Old Aug 1, 2008 | 04:54 PM
cxSHOE's Avatar
Default Re: (BrakeExpert)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrakeExpert &raquo;</TD></TR><TR><TD CLASS="quote">Those brackets are not milled or grinded. they are stock.</TD></TR></TABLE>
i would agree, the grinding would be completely across. its just brake residue surrounding the outline of the knuckle area.
Old Aug 1, 2008 | 08:03 PM
slofu's Avatar
aren't prelude vtec rotors 25mm thick (like S2K), don't they use the 25T brackets?
I use the Legend GS 28mm thick rotors with the appropriate calipers/brackets. The extra venting helps, but I do have to redrill to 4X100.
JayBinNyC88
Honda Civic (2006 - 2015)
Jan 10, 2007 02:31 PM
George Knighton
20
Apr 17, 2006 09:30 PM
VELOCITY R
Acura NSX
Apr 19, 2004 11:27 AM
morph
Jan 27, 2004 12:15 PM
99DXcoupe
Jul 2, 2002 06:23 PM
